Old 08-30-2015, 07:31 PM   #1
canadian_diesel1964
Anyone done a T5 in a 63 Short bed?
I have a chance to buy a 1985 Camaro rebuilt T 5 with a s10 tail stock on it for my 63 . Is there something about moving the e brake cable assembly? Any help is always appreciated..thank you
canadian_diesel1964 is offline   Reply With Quote
Old 08-30-2015, 07:42 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: Anyone done a T5 in a 63 Short bed?
I also have a Camaro T5 with a S10 tail stock in my 1965 C10. Your cab is the same except for windshield/doors/dash. I'll assume you have a low hump which is fine. You will love the T5.
You can go 2 different ways with the e-brake mod. You can keep the frame crossmember that holds the factory e-brake assembly and just mount it BELOW the frame rail using spacers like shown in the first photo (1965 C10).
Or you can convert the whole e-brake setup to a 1966 style which eliminates the bracket altogether (which is what I did).
I'd say moving the frame crossmember below the lower frame rail is the most straight forward solution and is cheaper since you essentially will have nothing to buy.
To each his own. I had the parts I needed already for the 66 conversion so I did that but used my original 1965 rear cables.
I'm also gonna send you a PM.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 08-30-2015, 07:46 PM   #3
canadian_diesel1964
He he I was just on you pages man !! Thank you
