Old 08-30-2015, 10:11 PM   #1
lowlife21
Don't know what to do
I have converted not only a manual transmission but also got rid of the automatic steering column to a floor shift column now the dilemma is I used the neutral safety switch from the auto column but it the sometime get hit and then will not start and I will need to play around to find the right setting on it to get it back to running what can I do to by pass this and make things run right
lowlife21 is offline   Reply With Quote
Old 08-30-2015, 10:15 PM   #2
midnight rambler
midnight rambler's Avatar
Re: Don't know what to do
Bypass the switch wire the leads together
midnight rambler is offline   Reply With Quote
Old 08-30-2015, 10:23 PM   #3
lowlife21
Which ones I have a light and dark green then there is also I believe one more connector that is two purples?
Old 08-30-2015, 11:26 PM   #4
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
The purple goes to the starter, jump them together. That should get the starter working.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-30-2015, 11:39 PM   #5
cooperhw
cooperhw's Avatar
You can take a 2" piece of wire and strip each end. Fold it in a horseshoe shape & insert into both wires (formerly)connected to the neutral safety switch. Caution. It will start in gear.
cooperhw is offline   Reply With Quote
Old 08-31-2015, 05:46 AM   #6
lowlife21
Thanks guys
