08-31-2015, 02:01 PM | #1 |
to gasket or not to gasket, that is the question
I have heard some people run gaskets and others don't? I was thinking of using gaskets. I cleaned and decked both surfaces. What do you guys think/recommend or have heard of?
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
08-31-2015, 02:15 PM | #2 | |
Re: to gasket or not to gasket, that is the question
Now comes the part your wife is really going to love. Set your oven to 350 degrees, get a baking dish and put 1/2 inch of sand in the bottom. Put the copper gaskets on top, cover them with another 1/2 inch of sand and bake them for two hours. Turn the oven off and let it cool back to room temperature before opening the door. Your gaskets are now annealed and will be very soft. Soft enough to compress when the manifold is torqued down. Just remember, if you ever need to loosen those bolts, you will need a new set of gaskets. |
08-31-2015, 02:17 PM | #3 |
i've always used gaskets, some of the new gaskets really do a good job, i've never heard of not using gaskets, and i've been a mechanic for over 27 years now
"Send in the clowns the goats are loose" |
08-31-2015, 02:19 PM | #4 |
Yes. I run the perforated metal type.
08-31-2015, 02:20 PM | #5 |
I always use a gasket. And I like the metal-sandwich version on both headers and cast manifolds. Gaskets dry, anti-seize on the bolts.
08-31-2015, 02:43 PM | #6 | |
08-31-2015, 03:49 PM | #7 | |
08-31-2015, 03:58 PM | #8 |
Junior Member
I run the manifolds with no gaskets and no leaks.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
08-31-2015, 04:01 PM | #9 |
Sanderson uses a 1/8 in wide by 1/16 in high sealing ring machined into the aluminum header flange on their headers. No gaskets. If you use locking fasteners, or just keep the bolts properly torqued they will never leak.
08-31-2015, 04:56 PM | #10 |
No gaskets from the factory. If they were decked correctly, and verified flat with a level, they'll be fine without gaskets. I have a good number of miles on mine, leak free. Best of luck with your decision.
08-31-2015, 06:28 PM | #11 |
Where did you get the phonelic material to make your own?
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
08-31-2015, 09:56 PM | #12 |
Absolutely use gaskets.
08-31-2015, 10:18 PM | #13 |
Unless you have two flat surfaces, which you don't from looking at the first image. Use gaskets.
09-01-2015, 09:54 AM | #14 |
Lets just say it fell off a truck about 7 years ago.
09-01-2015, 09:55 AM | #15 |
I do have 2 perfectly decked surfaces. the pic is just in the middle of the process. That's why I'm asking if to use gaskets or not.
09-01-2015, 10:21 AM | #16 |
How did you deck the surfaces? Use gasket, I have never removed a manifold that did not have a gasket.
09-01-2015, 10:23 AM | #17 |
If you're trying to keep heat away from your carb, you need a heat shield instead of a spacer.
Especially with a holley. https://www.holley.com/products/fuel...s/parts/108-70 |
09-01-2015, 10:28 AM | #18 |
09-01-2015, 10:29 AM | #19 | |
09-01-2015, 10:31 AM | #20 |
Yup, I have a machined straight edge and a machined 2 foot sanding bar. all surfaces are flat with each other. Took me 4 hours to do the block and headers. It was not fun.
09-01-2015, 10:36 AM | #21 |
Cool deal. Was just asking since I have seen a lot of sbc heads blown out at the gasket surfaces from them just being sanded smooth with a disk.
09-01-2015, 11:00 AM | #22 |
09-01-2015, 11:13 AM | #23 |
...for a structure borne heat transmssion path.
You also need the shield for convection (air borne heat path). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-01-2015, 12:42 PM | #24 |
I respect the effort that went into "decking" the heads and manifolds. However, dropping in a good set of soft aluminum gaskets would give you the same result without all the elbow grease. I did that many years ago and never looked back. The aluminum gaskets are also reusable if you have to pull a manifold. BTW, have you fired the engine without gaskets to check the decking job? That should answer your question.
09-01-2015, 01:45 PM | #25 |
