Old 08-31-2015, 11:36 PM   #1
drewbert41
drewbert41's Avatar
Exterior Door Handle Question
Both of my door handles are pretty loose. I tried to tighten them and it is no they are as tight as they will go. The rubber behind them has seen better days.
Is this rubber the issue? If I replace it will they be tight again?
drewbert41 is offline   Reply With Quote
Old 09-01-2015, 12:00 AM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Exterior Door Handle Question
They should tighten regardless of the rubber...Might try a flat & lock washer on the bolts. Check for corrosion in the bolt holes and maybe the bolts were replaced at one time with slightly longer bolts...?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 09-01-2015, 12:26 AM   #3
69chevytrucker
69chevytrucker's Avatar
x2
69chevytrucker is offline   Reply With Quote
Old 09-01-2015, 12:34 AM   #4
drewbert41
drewbert41's Avatar
I was wondering about the longer bolts. Not sure why they would have done that, but I will look into it. I am glad that I didn't order that rubber piece already.
Old 09-01-2015, 08:16 AM   #5
drewbert41
drewbert41's Avatar
Does anyone know exactly what size bolt I need?
