Old 09-01-2015, 02:51 PM   #1
Shtudwn
66 Wiring help for HEI
I have added an HEI distributor and need some help on the wiring.
I have the two yellow wires that used to go to the points distributor
a green wire and a black wire with a rubber connector. There are another set of wires that have been taped up prior so I'm thinking not important yet....
Anyone have ideas with the colors described before I start testing?
Thank you.
Shtudwn is offline   Reply With Quote
Old 09-01-2015, 03:39 PM   #2
Shtudwn
Re: 66 Wiring help for HEI
OK, after cleaning and removing the harness tape here is what I have found.
Dark Green
Light Green
Blue (w/ rubber connector)
Yellow
White(braided)
The white(braided) wire is connected to the yellow with a spade terminal that I think went to the old distributor.
Thanks.
Old 09-01-2015, 08:01 PM   #3
PGSigns
PGSigns's Avatar
For the HEI you will want to run a new wire from the fuse box. There should be a terminal that is only hot with the key on. Run a new wire off that. That way you don't have a resister wire running to it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-01-2015, 09:48 PM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
Tape up all the old wires from the coil. You can also use the pink wire going to your ignition switch. If you can go to a bone yard and cut a wire from an HEI as long as you can. I believe you can buy them also. Here http://www.summitracing.com/search/p...wer%20Pigtails Get the two wire if you are going to run a Tach.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-01-2015, 10:00 PM   #5
69chevytrucker
69chevytrucker's Avatar
one hot off your key and another for your tach is all the hei needs
69chevytrucker is offline   Reply With Quote
Old 09-01-2015, 11:41 PM   #6
ACK
ACK's Avatar
Make sure to pull that white braided wire and toss it as far from your truck as possible, then find it and toss it a again. That resistor wire is a major pain in the @ss if hooked up to the HEI.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 09-02-2015, 12:25 AM   #7
Shtudwn
So dont just replace the braided wire. Run a new wire from the fuse block to the hei?
Old 09-02-2015, 12:42 AM   #8
ACK
ACK's Avatar
Here's a good HEI swap thread that covers wiring ... http://67-72chevytrucks.com/vboard/s...d.php?t=599564
I'm also throwing in a shot of the wiring harness for a 6 cylinder with dummy lights. If I recall correctly, it uses type 56 terminals. BTW, it's a pic prior to swapping out to an HEI ...
Old 09-02-2015, 02:32 AM   #9
WOLFMANmike
WOLFMANmike's Avatar
as stated above find a switched power source on the fuse box use red color run it from that source to the terminal for it i believe it says batt on it but don't quote me the other terminal is for a RPM Tach so it you run one hook it up there and if not then don't worry about it .. now as for the old wiring its all useless but and im not bashing anyone . i just feel like maybe you would like to know why it is useless and i saw that it was not explained yet . so here it is in simple terms .. the points distributor can only handle so much voltage going to the points so they put that white braided wire AKA resistor wire in line to reduce the voltage so that your points wont cook ... a common mistake lots of people make when changing over to HEI is they use that wire and it will start and run but it runs badly because the HEI is not getting full voltage . so you get popping and sputtering under a load .. next im not sure if this is your 1st HEI Swap or not or even what engine your doing it in but lets just say if its a V8 after stabbing in the HEI go to your local parts store and buy a HEI re curve kit and fallow the directions on the package for your weight of vehicle and re curve it for that this is so that your new HEI Swap is tuned to your truck and engine a good match . this is done because some people will go pull a HEI out of a car lets say and put it in a bigger heaver car or truck and now the HEI isent giving optimal timing advance ... after this re curve kit is done simply set the initial timing at 12 to 13 degrees and your done should only take you about a Hour for the whole thing ... Happy Truckin
WOLFMANmike is offline   Reply With Quote
Old 09-02-2015, 08:25 AM   #10
cg285
an easier way is to use the existing coil wire to trigger a bosch relay and run the hei power from b+ on the starter. use a 16 gauge fusible link off the starter connection.
cg285 is offline   Reply With Quote
Old 09-02-2015, 08:41 AM   #11
Lugnutz65
Lugnutz65's Avatar
Don't use just any gauge wire to the HEI. Make sure it's a 10 gauge.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 09-02-2015, 08:45 AM   #12
cg285
10 gauge is fine. so is 12 but if you use a fusible link don't run a 10 gauge link
Old 09-02-2015, 11:00 AM   #13
Shtudwn
Thank you all for such great info. Im going to hit it today and see if I can get everything running.
