Old 09-02-2015, 10:56 PM   #1
BCOWANWHEELS
whats this wire for ?
on the battery cable positive there is a small wire like #12 or 14 size that goes about 6-8" to a small bakelight block with a stud in the center. could somebody tell me the purpose of this and where it goes ?
thanks
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-02-2015, 11:16 PM   #2
leftybass209
leftybass209's Avatar
Re: whats this wire for ?
I think your talking about the junction block on the passenger fender. It is a distribution block for positive power wiring. Look up some schematics here if you'd like to know where those wires go.
It's also entirely possible you have an aftermarket positive cable with a small gauge lead that runs anywhere a previous owner wanted it to.
leftybass209 is offline   Reply With Quote
Old 09-03-2015, 07:56 AM   #3
67 chevelle
67 chevelle's Avatar
Probably the charge wire for your battery ,, they were ridiculously small from the factory
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 09-03-2015, 08:18 AM   #4
sduckworth13
sduckworth13's Avatar
Here is a thread with information on the fusible link.
http://67-72chevytrucks.com/vboard/s...d.php?t=545962
Scott
sduckworth13 is offline   Reply With Quote
Old 09-03-2015, 10:25 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: whats this wire for ?
The block on the passenger side fender is to attach hot wires off of instead of the battery it self.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-03-2015, 01:17 PM   #6
BCOWANWHEELS
THATS the one I,am referring to fellas
Old 09-03-2015, 01:26 PM   #7
67 chevelle
the gray ones your battery charge wire/ power to fuse block , the black one Im not sure traced it back the loom to a junction by my horn relay , unhooked it , cant figure what it was , it was defiantly factory installed just like the picture , on a 67 , have not had an issue , there was a small glass fuse in it
Old 09-03-2015, 01:34 PM   #8
bigmac73
bigmac73's Avatar
those glass fuses are for your amp meter there should be one on each side of the engine compartment
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 09-03-2015, 01:39 PM   #9
67 chevelle
great info , I made the switch to a volt meter , probably why I have no issue
Old 09-03-2015, 07:43 PM   #10
EARNHARDT#3
EARNHARDT#3's Avatar
Never knew this! Exactly where are these fuses? Might be why my amp meter doesn't work.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 09-03-2015, 08:13 PM   #11
WorkinLonghorn
WorkinLonghorn's Avatar
I just replaced one today. Just look in the corner next to the pos. battery terminal. Follow the small gauge wire coming off the little distribution block there.
Then look in the area of the voltage regulator. Same size and color, same style pull-apart in-line fuse holder.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 09-04-2015, 08:12 PM   #12
EARNHARDT#3
Well, checked mine and they were both blown. Grabbed 5 new ones from the parts store for 30 cents each. Popped them in and the gauge still doesn't work. I looked on the backside of the gauge and two of the posts are connected to the printed circuit board and the 3rd isn't coneected to anything. Not sure if it's supposed to be.
