Old 09-03-2015, 09:19 PM   #1
Mmorgan32
Mmorgan32's Avatar
What do s the stock ride height of a 3/4 ton
Does anyone know the actual ride height of a 70 3/4 ton from the factory? I'm about to buy new springs and I want my truck 1 in lower in the front and about 2 inches in the back and don't know what size lowering springs to get. I want my truck to look stock just not so high I am not a tall guy and right now it's just a hair to high for me ( I have stock 45 year old springs)
1972 gmc c15 short bed... Sold
1970 chevy custom camper patina daily driver
Mmorgan32 is offline   Reply With Quote
Old 09-03-2015, 11:52 PM   #2
Clavo106
Re: What do s the stock ride height of a 3/4 ton
im also curious since the PO cut the spring on the 3/4 ton.
Clavo106 is offline   Reply With Quote
Old 09-04-2015, 12:11 AM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
You might consider that 1-2" may not change your stance much, if at all. As you say, your springs are 45 years old, so they probably sag. You might get an idea how much sag with equal air pressure in the tires and a tape measure, but even that won't say much. My first thought for your 1-2" is simply 1-2" drop coils. Maybe some blocks.
I don't know the correct height and good luck finding someone who does. I only know the rear was 2-3" taller. Most people say 2". One way to confirm that is for someone with say a 2/4 drop. If their truck is level (with same tires/wheels), then it was 2". I suspect it's somewhere between 2-3".
This drop business is all new to me. I'm looking into a 2/4 or 3.5/5.5. Found this webpage just a moment ago. Good information: http://www.stylintrucks.com/Articles..._glossary.aspx
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-04-2015, 12:18 AM   #4
Mmorgan32
Mmorgan32's Avatar
Originally Posted by 71CHEVYSHORTBED402 View Post
You might consider that 1-2" may not change your stance much, if at all. As you say, your springs are 45 years old, so they probably sag. You might get an idea how much sag with equal air pressure in the tires and a tape measure, but even that won't tell much.
I don't know the correct height and good luck finding someone who does. I only know the rear was 2-3" taller. Most people say 2". Seems the best way to confirm that is someone with say a 2/4 drop. If it's level, then it was 2". I suspect it's somewhere between 2-3".
That's why I want to know what the stock height is so I can get an idea of how much mine has sagged
Old 09-04-2015, 12:47 AM   #5
71CHEVYSHORTBED402
I'll be watching.
Tony
Old 09-04-2015, 08:56 PM   #6
Ram-Man
Ram-Man's Avatar
First pic front. 67 GMC C20 with 50,000 miles on it. All original sitting on a concrete floor. Leaf spring rear.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 09-04-2015, 09:36 PM   #7
Mmorgan32
Mmorgan32's Avatar
Awesome thanks man
Old 09-04-2015, 09:47 PM   #8
Ram-Man
Ram-Man's Avatar
Awesome thanks man
No problem. Figured I better measure it my Porterbuilt stage 1 front and stage 2 rear showed up today. I feel a little guilty baggin it because the truck is so nice.
Old 09-04-2015, 10:03 PM   #9
Mmorgan32
Mmorgan32's Avatar
One day when mines not my daily driver I'll slam mine
