Old 09-05-2015, 03:00 PM   #1
Malamute
Malamute's Avatar
Looking for a pedal rod extension
Installing the MC and booster and the one in the old booster is not the same for current booster. It has male threads coming out and I need a female threaded clevis that is about 4" long.
I've found a few but they are all twice as long as I need or just the clevis which is too short. Any thoughts on where I can find something? Needs to be just a bit longer than this one.
http://www.mbmbrakeboosters.com/inde...emart&Itemid=6
Thanks.
Malamute is offline   Reply With Quote
Old 09-05-2015, 03:10 PM   #2
cdowns
cdowns's Avatar
Re: Looking for a pedal rod extension
take a hacksaw and cut one of the long ones down to proper size
Old 09-05-2015, 03:20 PM   #3
Malamute
Malamute's Avatar
Problem is, it's female threaded and I don't know if the threads extend all the way up. I think I found one that I can get in 4" length that should work. Thanks.
http://www.fabquest.com/brake-booste...-8-eyelet.html
Old 09-05-2015, 09:16 PM   #4
Money_pit
Money_pit's Avatar
With a little bit time and patience I made an extension out of a piece hex shaft solid stock drilled each end and tapped it.made it like a longer than normal adjuster. I went with a dual diaphragm 7" or 8" booster. And was about 3" short
71 C10 Finally took a leap and did the 5.3 4l80e swap.
Running the Holley Terminator Xmax. Still working bugs out.
Money_pit is offline   Reply With Quote
