#151 |
![]() Join Date: Feb 2011
Re: Hydroboost Mounting Plates
I see what you are saying now that i have removed the old booster.So i will not need your hydroboost plate.
Thanks Kenny |
#152 |
60-66 Nut
You could always convert to hydroboost using the correct booster bracket and this hydroboost mounting plate.
#153 |
60-66 Nut
I have the hydroboost nut sockets back in stock.
#154 |
![]() Join Date: Jan 2012
I would like to order a bracket for a 1962 truck thanks
#155 |
60-66 Nut
I'll sent you a PM with ordering info.
#156 |
I need the information on ordering the 67-72 bracket (powdercoated) and the hydroboost bracket. Send the info to vratman@sbcglobal.net
Too many dreams, too little money. |
#157 | |
60-66 Nut
Email sent.
#158 |
![]() Join Date: Sep 2003
I will need the bracket and plate as well for my 72 Suburban. Please message me and let me know if you have this in stock. I will paint it. Thanks Scott
#159 |
60-66 Nut
I will send you a PM with ordering and payment info.
#160 |
Moderator
![]() ![]() Join Date: Aug 2011
Would a 94 Chevrolet K3500 Diesel Hydroboost work with your mounting plate?: http://www.cardone.com/Products/Prod...=527334&p=rock
and http://www.rockauto.com/dbphp/x,carc...e_Booster.html
#161 | |
60-66 Nut
Yes it will work.
Once you remove the factory mounting bracket all GM hydroboosts are interchangeable. Quote:
#162 |
i want a hydroboost bracket and i guess a power brake bracket for my 72 cab! black powdercoating if available please. doing a complete setup from a chevy 2500HD (hydroboost and master cylinder)
#163 |
60-66 Nut
#164 |
Need Paypal info for a hydroboost mounting plate...
'65 Tiki Sea 10: http://67-72chevytrucks.com/vboard/s...d.php?t=682356 |
#165 |
60-66 Nut
#166 |
I will be converting my 62 Corvette to Hydroboost so will your bracket fit the firewall mounting bolts where the stock M/C is located?
Here is the HB unit I am using, it came from a 2000 ford GT so I guess I will need the Nut removal tool also, what else will I need?
#167 | |
60-66 Nut
Sorry but I have no idea what the firewall hole pattern is for the master cylinder on a '62 Vette. If by chance it was the same as these hydroboost mounting plates, you would still have to enlarge the center hole a bit. These plates are intended to be used with my booster brackets so that no modification to the firewall is necessary. that also maintains a good solid connection between the booster/master and the pedal bracket as GM designed it to be.
#168 |
Thanks,
I will wait until I get the car back and take some measurements and pics.
#169 |
I would like info on your booster bracket and hydroboost mounting plate. Please PM me the info. Thanks
#170 |
60-66 Nut
#171 |
![]() Join Date: Feb 2014
#172 |
Looks Great! I like the look of the flat plate directly on the firewall instead of the use of the adaptor bracket. Any more pictures? What did you do to the pedal and linkage to make the connection?
#173 |
That looks much better than the old booster and bracket sticking out into the engine bay.
Jack Byrd '70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4 '76 Airstream Argosy MH(want a longer one), 454CID, TH400 |
#174 |
I have an 89 Suburban V1500 I am doing hydroboost on, so I am in the market for a bracket/plate assembly.
I have a hydroboost from a 99 silverado I plan on using but the mounting between the two is fairly different. Heres the hydroboost I have: http://i.imgur.com/B9vdQZK.jpg The issue I have is that two of the holes on the firewall (and on the pedal assembly) are to the sides of the larger push rod hole and not above it. Also, there are 6 bolts on the booster, two up at the very top, that I assume I just wouldn't need anymore. Here is a picture of my firewall to get a better idea: http://i.imgur.com/Gvulyo6.jpg Is this a part you make or can make? |
#175 |
60-66 Nut
All you need is a factory hydroboost mounting plate for a '73-'86 C/K or a '87-'91 R/V truck, Suburban or Blazer. Then just remove the factory '99 mounting bracket and install the earlier one. As for connecting to the pedal, some fabrication may be needed. I'm not sure as I have not done anything like this. It would likely be a whole lot easier to just get a '73-'86 C/K or '87-'92 R/V hydroboost and bolt it up.
