Old 09-06-2015, 06:03 PM   #1
gramps77
Door windows slide back and out of track
Is there a spring or retainer that should keep the windows forward and into the track so that the dont slide back?
I dont have the inner door panels on yet because they didnt do it right before I took the panels off prior to paint but think that maybe the inner window felt on the panel may help keep them outboard and more prone into the track. Is that correct?
gramps77 is offline   Reply With Quote
Old 09-06-2015, 06:43 PM   #2
tommy217xxx
tommy217xxx's Avatar
Re: Door windows slide back and out of track
Mine does the same thing so I'd be curious to know as well
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 09-06-2015, 08:36 PM   #3
bmchevy1979
bmchevy1979's Avatar
On my 74 and my 76 the bracket that holds the bottom of the rear window channel breaks the spot welds and the channel doesn't hold window forward anymore allowing window to fall out of the channel I just put window back in track rolled it up and tack welded it back into place
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 09-07-2015, 12:25 AM   #4
plumbers crack
plumbers crack's Avatar
Mine did the same thing. Aside from the bad track rubber, I found the bolts to the track a little loose, readjusted the tracks and tightened them up. I'll have to do it again when the new track rubber gets put in.
1990 GMC R35 CC dually, VE cummins, 47RH
2005 Silverado ecsb, 5.3, 2/4 drop, daily work wagon
2000 Yukon xl, 5.3 all stock, wife's truck
2007 Yukon Denali, 6.2 back up truck
plumbers crack is offline   Reply With Quote
Old 09-13-2015, 07:39 PM   #5
gramps77
Anyone have a pic of this bracket? It was just odd that both windows started doing it at the same time on my truck
Old 09-14-2015, 07:28 PM   #6
bmchevy1979
Here are some pics from a spare door I have you can see the tack welds pic 2 is the bolt holding the bracket also if it hasnt broken loose they do bend very easily so it may have been bent back allowing the window to fall off track
<Brandon>
Old 09-18-2015, 11:50 AM   #7
gramps77
Im trying to understand orientation there. Thanks for the pics though, at least I know the area to look in
Old 09-18-2015, 08:54 PM   #8
bmchevy1979
Sorry pics got turned by phone look toward back of door through the opening above the armrest bracket that is the rear window channel in pic
<Brandon>
Old 10-10-2015, 07:35 PM   #9
gramps77
My rails are not cracked or separated. When you go to roll the window down now, even with the door panels in, they slide back and away from the forward window channel and you then need to guide them by hand back up.
They didnt do this BEFORE getting my vent windows rebuilt/resealed and now its a pain, especially with my kids riding in it sometimes.
Old 06-28-2017, 08:35 AM   #10
gramps77
Still dealing with this years later. I think my explanation was confusing. The window pops out of the door guide/track that it seals up into. If driving, the wind will pull the window out enough that I rolls up outside of the door frame if I don't hold it forward into the door frame/seal. Like there should be a spring or something holding tension forward. Any ideas?
Old 06-28-2017, 12:24 PM   #11
chrismoore701
chrismoore701's Avatar
There has to be something out of alignment inside your door. Pop you panel off and look inside. The rear slide should move forward. I had to actually cut a notch in my door to get it to adjust forward enough to hold the glass tight. I am guessing your rear slide is either loose, or broken. mine was both
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 06-28-2017, 10:31 PM   #12
TKCR
TKCR's Avatar
There are several videos you can watch on youtube to understand the entire door and window setup. Here's a few:
https://www.youtube.com/watch?v=T3v6uZarxKA&t=8s
https://www.youtube.com/watch?v=JGMKPuS1NJQ&t=197s
https://www.youtube.com/watch?v=raKdxJEJsJU&t=16s
