Old 09-06-2015, 06:49 PM   #1
donpr
donpr's Avatar
switched eddy 750 to holley 750
I switched my eddy 750 to holley 750 and found I'm getting more power and better fuel economy. Still think I need lighter vacuum spring tho. Has anyone else noticed the difference in these carburetors ? The eddy was just to sluggish. Here's what its in
donpr is offline   Reply With Quote
Old 09-06-2015, 07:07 PM   #2
jayoldschool
Moderator
Re: switched eddy 750 to holley 750
Big block? An Edelbrock 750 is too big for a small block. I run a 1405 600CFM Edelbrock on my my 71 350.
jayoldschool is offline   Reply With Quote
Old 09-06-2015, 07:16 PM   #3
donpr
donpr's Avatar
its on a 383 stroker, 86 k20. jasper engines class 2, I dont think its too big ...got lots more power now .
Old 09-06-2015, 07:16 PM   #4
hugger6933
the only time I saw a 750 Edelbrock work on a small block was with a underhood blower. Jim
hugger6933 is offline   Reply With Quote
Old 09-06-2015, 07:20 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Any carb can work fantastic...or any carb can work like crap. Doesn't matter the manufacturer if you don't know how to tune it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-06-2015, 07:33 PM   #6
donpr
donpr's Avatar
I tried all the different metering rods and different jets in edelbrock 1489 calibration kit with no luck. I finally had enought and put on 3310 yesterday. Im glad I did.
Old 09-06-2015, 07:41 PM   #7
geezer#99
geezer#99's Avatar
And it likely wasn't even a carb problem!!
Good move on the holley though.
Now before you start tweaking the holley, optimize your timing first!
Old 09-06-2015, 07:51 PM   #8
donpr
donpr's Avatar
It could be timing , it was 16* at idle, but I dont trust my dissy. I bought a complete other one, but ran out of time to install. This carb still pulls harder than eddy did... just my opinion
Old 09-06-2015, 08:02 PM   #9
geezer#99
geezer#99's Avatar
And it'll start better too!
Especially when it gets colder this fall.
You did plug your vac advance off when you checked timing, didn't you?
Have you proved your balancer/timing tab are correct?
Old 09-06-2015, 08:31 PM   #10
donpr
donpr's Avatar
yes I plugged vacuum advance and no I didnt prove timing tab. That is a good point. Will check .
Old 09-06-2015, 08:36 PM   #11
geezer#99
geezer#99's Avatar
Info for you.
http://www.crankshaftcoalition.com/w...op_dead_center
Old 09-06-2015, 08:51 PM   #12
donpr
donpr's Avatar
very good reading ...will read later..
Old 09-06-2015, 09:02 PM   #13
donpr
donpr's Avatar
heres my engine specs http://www.jasperengines.com/pdf/Cla...20Stroker%2009
Old 09-12-2015, 08:48 AM   #14
Daman
I swapped everything over to Holley a couple years ago. The reason was how far Holley has come with their products. Power, mileage everything. Back to set it and forget it.
Don't get me wrong I'm a carb guy and have had Edelbrock, Quadrajets, old Holleys and a few oddball ones. These are all on daily driven vehicles and one weekend fun/race vehicle.
Daman is offline   Reply With Quote
Old 09-12-2015, 09:30 AM   #15
HeavyD
HeavyD's Avatar
Using the term set it and forget it and Holley in the same sentence? I guess things have changed.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 09-12-2015, 10:29 AM   #16
EARNHARDT#3
EARNHARDT#3's Avatar
You haven't lived until you have a 1bbl Rochester B. LOL
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 09-12-2015, 11:49 AM   #17
Jonlopes
Sorry to go off topic but is 750 cfm too big for a stock 396/402?
1971 Cheyenne Big Block Longhorn
Jonlopes is offline   Reply With Quote
Old 09-12-2015, 04:01 PM   #18
elkniks
elkniks's Avatar
In my experience it depends on how much flow your engine has. I just installed a 770 cfm on a 350 that I am putting larger jets in this weekend because it is running too lean.
elkniks is offline   Reply With Quote
