09-07-2015, 09:00 AM | #26 |
Re: crossover steering
Yeah cross over steering uses a 2wd steering box and the sway bar can be kept with a little work http://www.pirate4x4.com/forum/chevy...g-swaybar.html but no clue on a swaybar and a track bar tho.
09-07-2015, 11:17 AM | #27 |
Currently Blazerless
I'm going to have to give this a try, I always assumed that a track bar with leaf springs would limit axle articulation. After seeing the way it's set up it makes more sense. I know this is totally different from a sway bar but looks like it may help with body roll (lean) as well?
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
09-07-2015, 11:22 AM | #28 |
Correct, your using the stock Chevy short and long drag link ends.
09-07-2015, 03:18 PM | #29 |
I had mine setup with a swaybar, but then I took it off and don't notice a difference. it doesn't lean even without it on there. and I rally this truck thru the back roads quite a bit!
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
10-09-2015, 08:50 PM | #30 |
6>8 Plugless........
If you look at a 86-97 Ford F-350 with a D60, they came factory with a track bar from the factory. They had the shackles up front and without the track bar the truck drove like you had loose front wheels.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-05-2015, 11:50 PM | #31 |
I'm running PartsMike high steer & cross over steering along with PSC hydraulic assist. Couldn't be happier.
