Old 09-07-2015, 06:04 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Help - Painting the Underside of Cab
I am about to paint the underside of the cab. I want to turn it over on its backside like I have seen others do on here. I'm concerned about the roof lip lying on the plywood I am laying down first.
Is there a trick to this or something to watch out for when doing this?
Any past experience would be appreciated.
Old 09-07-2015, 06:14 PM   #2
revjames
Re: Help - Painting the Underside of Cab
I am very interested as well I was just pouring through past threads to try and figure this one out. Can Yu do it with the windows in and doors on
revjames is offline   Reply With Quote
Old 09-07-2015, 06:15 PM   #3
The Rocknrod
Moderator
My doors are off with no glass or anything else in the cab for that matter.
Old 09-07-2015, 06:19 PM   #4
revjames
Oh well then you can easily lay it on its back with out bending anything have done it several times. Good luck
Old 09-07-2015, 06:26 PM   #5
spookylynx
spookylynx's Avatar
Mine had doors and glass out, but there is no difference aside from weight. I just flipped it over using a ceiling hoist. (I was solo)
You shouldn't hurt anything as long as you don't drop it when you flip it up, just get a couple friends and lay it back gently. You could even put a blanket or some foam down under the lip if you are really that worried.
spookylynx is offline   Reply With Quote
Old 09-07-2015, 06:54 PM   #6
OldChevy61
OldChevy61's Avatar
Mine is on its back now. Doors off,glass still in. Doing under the floor and roof at same time. Mine is laying on 4x4s. As long as you don't drop,you will be fine.
OldChevy61 is offline   Reply With Quote
Old 09-07-2015, 07:01 PM   #7
The Rocknrod
Moderator
Are the 4x4's under the lip across the cab? And across the bottom?
Old 09-07-2015, 07:21 PM   #8
cv65
cv65's Avatar
you can set it on its back or front as long as you dont drop it
cv65 is offline   Reply With Quote
Old 09-07-2015, 07:22 PM   #9
OldChevy61
OldChevy61's Avatar
Here ya go.
Old 09-07-2015, 07:30 PM   #10
The Rocknrod
Moderator
That tells the story guys. Thank you.
I have people coming over tomorrow to help me turn it over.
This will be great help.
Old 09-07-2015, 10:10 PM   #11
TJ's Chevy
TJ's Chevy's Avatar
Beautiful cab! lol!
Old 09-07-2015, 10:43 PM   #12
Uptown83
I've been rolling my body on its back and firewall with no issues of damage.
Uptown83 is offline   Reply With Quote
