09-08-2015, 11:56 AM | #1 |
Seat question
I have a 76 1500 gmc that I want to put a current 40/20/40 split in it. Has any one tried this? Will it fit? I know I'm gonna need a extension bracket for the front feet of the jump seat and the inside front feet of the seats.
Thanks for any advice in the future on this topic.
TJ 76 gmc 1500 swb patina finish Dropped 4/5, 350/4 speed 80 Chevy c10 lwb 305/350 |
09-08-2015, 07:43 PM | #2 |
Re: Seat question
You will probably have to shorten the outer brackets instead of lengthening the others. When I put 08 Silverado seats in my K5 the height was just right but k5s have flat floors not like a c10 pickup with raised seat area also my seats the brackets were all the same length all the way across I think the newer seats straddle the tunnel and don't mount on top of it
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
09-09-2015, 10:37 AM | #3 |
Re: Seat question
Ok. I have 2009 Silverado with the split bench and it's the same height as the buckets my 76 has. I measured from where the seat tracks mount to the floor up to the top of the seat. The actual part that u sit on not the back rest. The buckets I have now had the inside legs extended with some 4x4 wood blocks.
09-09-2015, 08:06 PM | #4 |
Re: Seat question
I would have thought they would be to tall in a pickup but the 09 seats should be the same as my 08 so you shouldn't have to use the blocks of wood anymore. When I first put them in my truck three of the mounts bolted in and one was about an inch off but again it not pickup I did eventually make a new floor bracket just cause I needed something more sturdy as I wheel my truck hard so it's now bolted in with all 8 factory bolts
09-09-2015, 08:27 PM | #5 |
Re: Seat question
I'll take a few pics tomorrow. I think the wood block should come out and I'll fab up a bracket to mount it all to.
09-11-2015, 09:01 PM | #6 | |
Re: Seat question
Sorry for butting in OP |
09-14-2015, 12:41 AM | #7 |
Re: Seat question
No I don't have pics of it but all I ended up doing is on drivers side was make a frame out of 1in square tubing that was raise about 2in to the top and unbolted the factory mounts and bolted the sliders directly to the frame I made its pretty simple but passenger side was a little trickier cause I made it flip forward like stock I will try to get pics of my brackets
09-14-2015, 08:03 PM | #8 |
Re: Seat question
Took some pics today I used angle iron on my frame for sliders but square can be used as well for passenger side I had to cut original k5 front bracket down and put a piece of 10ga. sheet metal to allow it to bolt to seat frame not slider I didn't think I needed a slider on passenger side so I placed it as far back as I could the back bracket was unchanged other than putting a piece of 10ga. Across it. Both side panels still fit as well
09-15-2015, 11:35 AM | #9 |
Re: Seat question
Blazer floors are completely different than a truck floor and that wouldn't work the same.
09-15-2015, 12:37 PM | #10 |
Re: Seat question
Thanks for posting those pics bmchevy1979.
Yep and bmchevy1979 said exactly that in his first post. He was posting the pictures for me since I also have a Blazer and wanted to see how his turned out... |
