Old 09-08-2015, 03:05 PM   #1
Shawben88
72 Grille Question
Forgive me for my ignorance, I am very new to the C10 world. I purchased a 72lwb last month. I am starting to tinker a bit, would I be able to use the inner grille from a 70 in place of my 72?
Shawben88 is offline   Reply With Quote
Old 09-08-2015, 03:11 PM   #2
BrianG
BrianG's Avatar
Re: 72 Grille Question
First off, Welcome to the board! The inner grille of a 70 is completely differnet than a 72. You would have to use both the Outer and Inner grille's in order to do your swap, and in that case you could. 69 and 70 outers are the same and the inners are just slightly different between 69 and 70. 71 and 72 grilles are much closer to each other, if not the same. Post up some pictures of your new ride when you get a chance.
BrianG is offline   Reply With Quote
Old 09-08-2015, 03:29 PM   #3
Shawben88
That was a quick reply, thanks. I guess I should have been more specific. I want to know if I can do a swap because I like the look of the 70 better. Will the innerror and outer bolt right in the 72?
Old 09-08-2015, 03:34 PM   #4
Shawben88
Here is a pic.
Old 09-08-2015, 03:34 PM   #5
leftybass209
leftybass209's Avatar
The entire 69/70 grill assembly can be interchanged with the entire 71/72 assembly. There isn't anything on the grills that really interchange between the years other than clips.
The turn signals are in the 69/70 grill, and in the 71/72 bumper, so you'd have to figure that out as well.
leftybass209 is offline   Reply With Quote
Old 09-08-2015, 03:37 PM   #6
Shawben88
And another.
Old 05-23-2016, 08:54 PM   #7
Carlitosway
great looking truck
Carlitosway is offline   Reply With Quote
Old 05-24-2016, 08:47 AM   #8
72 Super
72 Super's Avatar
Welcome to the board. Great looking truck you have already. If you switch over to a 69-70 grill set up you will a 69-70 center grill brace also. They are different than the 71-72's
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
72 grille
