Old 09-12-2015, 09:41 AM   #1
lane224
lane224's Avatar
Steering problems
1986 k10 brand new 4" lift.
When making left turn Truck will suddenly jerk to the right and steering will get sloppy. Doesn't happen every time. Checked rag joint and all steering components all look good. Bad steering box? Power steering pump is a bit overfilled. Not sure what else to look for. Lift was installed before I bought truck so not sure if these symptoms were there before. Has the 4" raised steering arm. Is it possible I need to change the drag link also ?
Any help would be appreciated.
lane224 is offline   Reply With Quote
Old 09-12-2015, 07:05 PM   #2
obijuan
Re: Steering problems
Frame cracked?
obijuan is offline   Reply With Quote
Old 09-13-2015, 03:23 PM   #3
lane224
lane224's Avatar
Frame is good no cracks.
Old 09-13-2015, 03:55 PM   #4
ryanroo
ryanroo's Avatar
Perhaps the valve in the box is gacked out? Did it make noise or just feel like you suddenly steered right while :-/ the middle of a left turn?
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 09-13-2015, 08:02 PM   #5
lane224
lane224's Avatar
No noise. Not sure what valve your referring to ?
Old 09-13-2015, 10:45 PM   #6
ryanroo
ryanroo's Avatar
There is a valve on the steering shaft that directs pressure to the appropriate side of the ball screw piston depending on direction of shaft rotation. It may have an issue. I've never heard of that, but who knows.
72 K20 12v build
Old 09-13-2015, 11:03 PM   #7
jeffahart
jeffahart's Avatar
perhaps your being yanked from the rear and mistaking it for a steering component issue; when your issue is actually the rear no-slip or limited-slip mechanics!
White K20
jeffahart is offline   Reply With Quote
Old 09-14-2015, 06:47 AM   #8
lane224
lane224's Avatar
Just dropped the tranny to do rear main seal. Should have it back together by weekend. Will look into all of that. Steering fluid looks real dark red. Isn't it usually more of a clear fluid ?
Old 09-23-2015, 11:19 AM   #9
walkerb
walkerb's Avatar
Just had the same type of issue with my 86 k30
when cold or after making a sharp turn the steering wheel will jerk left or right. Scary! Then go away.
I did everything. Then I checked the front dana60 ujoints. WASTED. They were fighting each other.
Rise the front and lock the hubs IIRC, rotate the wheels by hand.
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 09-23-2015, 12:15 PM   #10
obijuan
Red fluid is just that someone put atf in the system instead of power steering fluid. Both are hydraulic fluids and have similarities. Not a big deal really.
Old 09-23-2015, 07:51 PM   #11
1976gmc20
Back in the "old days" they were the same thing
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 09-29-2015, 08:39 AM   #12
lane224
lane224's Avatar
Yes but this stuff is thick dark burnt red. going to replace fluid.
Measured the steering arm on my 73. Definitely has more rise than one on the K10. Purchased new 4" lift steering arm. Had 1" aprox. more rise than the one that was on there. Steering arm that was on there was definitely not original but I didn't think they made a raised steering arm for anything less than 4" lift so not sure. Axle also has some play in it on both sides. Going to replace all the wheel bearings on both sides but the new arm seems to have done the trick. truck is turning fine now. Thanks guys.
Old 10-01-2015, 12:50 AM   #13
Zane M
Check what the others have suggested, but I can say I had the exact same issue with my '87 V20 and it was the result of a bad steering box.
Changed the box and 2 years later no issues.
Zane M is offline   Reply With Quote
Old 10-03-2015, 07:48 AM   #14
The axle u-joints will only affect steering (or anything) when front axle is engaged in 4wd. People put ATF in leaky steering boxes, so that's a sign your box is crapped out. I wonder if the steering arm that was on it was for another application than GM. That inch difference is not enough to throw things off much at all.
Old 10-03-2015, 07:08 PM   #15
lane224
lane224's Avatar
Truck has been fine since I changed the steering arm. No steering problems at all. I would have to assume that made the difference. Just happy it's all good.
