Old 09-11-2015, 09:16 PM   #1
H20cooled
ECE front brake hose replacement?
I bought one of the ECE front disc brake conversions for my 68 C10 and I just found that one of my front rubber hoses got pinched and needs to be replaced. I was hoping to find a replacement at a local auto parts but I've had no luck so far.
Does anyone know of a good replacement for this? I was really hoping to get it fixed this weekend.
Thanks,
Rich
H20cooled is offline   Reply With Quote
Old 09-11-2015, 09:55 PM   #2
69chevytrucker
69chevytrucker's Avatar
Re: ECE front brake hose replacement?
why wouldnt one off a mid 80's truck work
69chevytrucker is offline   Reply With Quote
Old 09-11-2015, 10:00 PM   #3
leddzepp
Moderator
leddzepp's Avatar
They are conversion hoses, ends are different.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-11-2015, 10:02 PM   #4
H20cooled
someone mentioned a 78 Camaro hose in a post but I could not confirm the size on one. I would like it to be longer than this one.
Old 09-11-2015, 10:26 PM   #5
picklito
Napa 36616?
picklito is offline   Reply With Quote
Old 09-11-2015, 11:22 PM   #6
H20cooled
Originally Posted by picklito View Post
Napa 36616?
I can go and try it.
Old 09-11-2015, 11:59 PM   #7
picklito
Look it up on NAPA and I think you can get the specs so you know before you go. My NAPA had to order it... which took 4 hours to arrive!
NAPA is sometimes (not always!) a little more expensive. But most of the stuff is good and the catalogs and parts guys a little sharper. Been very helpful with the 70.
Old 09-12-2015, 12:04 AM   #8
H20cooled
From their description it sounds very close and they have one instock locally so I will go check it out tomorrow. Thanks
Old 09-12-2015, 12:28 AM   #9
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
If you have a local shop, have one made. I toyed a round a bit with some repro., sent em all back. Will have everything made instead.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-12-2015, 09:41 PM   #10
H20cooled
The Napa 36616 worked perfectly, it is a little shorter than the hose from ECE but everything else is the same. The shorter hose actually works better with the lowered truck now I don't have to worry about it getting pinched. Thank you picklito for the part number.
Old 09-13-2015, 02:25 AM   #11
picklito
Oh man thats great! That's the hose NAPA gave me to try for my swap, but I'm still a week or two away.
Old 09-14-2015, 12:43 AM   #12
leddzepp
Moderator
leddzepp's Avatar
Great info! I cross referenced the Napa part number with autozone and oreillys. They all carry them on the shelf, $9.95 each. I picked up a pair of hoses....AND new calipers, pads, and banjo bolts for the same amount of money it would have cost me for the hoses alone from ece. The hoses have been the only part keeping me from doing a budget disk brake conversion using off the shelf parts locally available.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-14-2015, 11:13 PM   #13
H20cooled
Excellent. You might share the other part numbers on here incase someone else needs the full set.
Thanks,
Rich
