Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 09-01-2015, 09:08 PM   #26
dbrandtlbrandt
Originally Posted by Captainfab View Post
If you don't want the clutch master cylinder, the cost is $50.00 less. Is the new brake booster you have compatible with my booster brackets? Are you wanting this in bare steel or satin black powder coat?
What is the total cost for these parts? What is your address? I would like to send payment. Thanks, Dave
dbrandtlbrandt is offline   Reply With Quote
Old 09-02-2015, 02:08 AM   #27
Captainfab
60-66 Nut
Re: '67-'72 Power Brake Booster Bracket With Hydraulic Clutch Conversion
Well with the regular cost for this conversion in bare steel of $207.50 minus $50.00 for the clutch master cylinder would come to $157.50 plus shipping of $16.35. I will send you a PM with payment info.
Old 09-02-2015, 01:16 PM   #28
dbrandtlbrandt
Old 09-02-2015, 01:17 PM   #29
dbrandtlbrandt
My email is dbrandtlbrandt@yahoo.com
Old 09-03-2015, 12:03 AM   #30
Captainfab
60-66 Nut
I replied to all of your emails today, received your payment and shipped your order.
Old 09-13-2015, 04:17 AM   #31
gringoloco
A guy with a truck
gringoloco's Avatar
From reading this, I gather that my 67-70 3/4T booster will bolt up, minus the current brackets/linkage? What, if any, disadvantage is there to not using the factory brake booster linkage?
Clutch linkage looks awesome, btw!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 09-14-2015, 12:00 AM   #32
kitsbeach
kitsbeach's Avatar
Curious about this too…I have a stock-style brake booster…want to add hydraulic clutch later…
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 09-14-2015, 01:22 AM   #33
Captainfab
60-66 Nut
Yes the '67-'70 brake boosters will bolt up to all of my booster brackets. At least all that I have seen or had my hands on have had the correct mounting stud pattern. I do not see any disadvantage to not using the bellcrank assembly that GM used for the pedal to booster linkage. I believe that was done to allow the downward angle of the booster/master assembly. In eliminating that linkage, you will simply have to trim both the booster pushrod and the pushrod from the pedal to achieve the correct length and weld them together. If welding is not an option a mechanical method will work as well.
Old 09-14-2015, 01:27 AM   #34
Captainfab
60-66 Nut
Please be aware that the flat base plate without the booster mounts as jlsanborn purchased is not a regularly offered part and you must specifically request that, if that is what you want.
Old 09-24-2015, 11:27 PM   #35
Captainfab
60-66 Nut
Here is a list of compatible brake boosters for all of my booster brackets. This list is included with every booster bracket.
'67-'70 pickups, Suburbans, Blazers
'70-'74 Impala, Caprice
'80's G body Vans (full sized)
Early Astro/Safari vans with the vacuum booster
'82-'02 S10/S15 pickups and Blazers
'88-'98 full sized pickups
'92-'98 Suburbans, Blazers
There may be some other applications, and/or years, but these are the ones I have been able to verify.
Old 09-25-2015, 11:13 AM   #36
ranger2339
ranger2339's Avatar
I will take one of these set ups. Doing a 5.3 with a T56, just not sure on the specs for the MC that I need?
ranger2339 is offline   Reply With Quote
Old 09-25-2015, 11:24 PM   #37
Captainfab
60-66 Nut
I'll send you a PM with ordering and payment info.
Old 09-27-2015, 09:29 AM   #38
vortech71chevy
What is the price for the kit with the plate that sanborn had made? will your kit work with the willwood master cylinder mentioned in the thread TR65 posted? I love your linkage mechanics and would much rather have something that clean, but I already have my brake setup done and already purchased that master cylinder for my t56 setup, i think that master has a 1.1 stroke?
"We must reject the idea that every time a law is broken, society is guilty rather than the lawbreaker. It is time to restore the American precept that each individual is accountable for his actions." Ronald Reagan
vortech71chevy is offline   Reply With Quote
Old 09-27-2015, 11:19 PM   #39
Captainfab
60-66 Nut
The total cost for one '67-'72 hydraulic clutch conversion with just the base plate and in bare steel with shipping is $191.85.
The linkage assembly is designed to work with a clutch master with a 1.4" stroke. You will have to install some sort of clutch pedal stop to keep from bottoming out the clutch master since is has a shorter stroke.
Old 12-22-2015, 08:04 PM   #40
tjsblazer
tjsblazer's Avatar
Captain. Couple of questions.
Does this linkage move the cylinder in a 1:1 ratio compared to pedal travel. In other words, you mention in a previous post that it moves the cylinder rod 1.4" the way it is set up. Does the pedal at the point of linkage move the same 1.4" or is it travelling further?
Reason I am asking is I may buy this set up from you but mod it slightly by moving the linkage and cylinder up a little higher to reduce the pedal effort. I just need to understand that stroke ratio.
Thanks for your help. Jeff.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 12-23-2015, 12:01 AM   #41
Captainfab
60-66 Nut
The linkage assembly allows full travel of the clutch pedal while only moving the clutch master cylinder's piston 1.40". The location on the clutch pedal arm where the linkage is attached, moves more than 1.40" Hence the need for the linkage assembly. Raising the clutch master cylinder up will severely limit the size of vacuum, booster that will work.
Old 12-24-2015, 03:27 AM   #42
kitsbeach
kitsbeach's Avatar
This might be a dumb question, but I don't understand why people need a booster bracket.? Don't we all have booster brackets if we already have power brakes.?
I think for me I just need the bracket that holds the clutch master cylinder, like jlsanborn bought.
Kitsbeach (Ken)
Old 12-25-2015, 10:44 PM   #43
Captainfab
60-66 Nut
Well for one, not all of the '67-'72 trucks came with power brakes. Secondly, not everyone likes the factory booster assembly that hangs 5 1/2" out from the firewall (me included) and would much rather have it tucked closer to the firewall. My booster brackets mount the booster 1 3/4" from the firewall measured at center.
I can sell you a kit with no booster brackets on the plate just as I did for jlsanborn., if that's what you really want.
Old 04-18-2016, 11:14 PM   #44
Captainfab
60-66 Nut
Bump for those having trouble finding this thread.
Old 04-27-2016, 03:41 PM   #45
duallyjams
duallyjams's Avatar
pm sent
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-27-2016, 11:11 PM   #46
Captainfab
60-66 Nut
PM replied to
Old 05-11-2016, 10:23 PM   #47
GoaterAz
GoaterAz's Avatar
PM Sent!
You remember when drinking too many beers was a bad idea?
Me neither.
GoaterAz is offline   Reply With Quote
Old 05-12-2016, 12:59 AM   #48
Captainfab
60-66 Nut
I replied to your PM........
Originally Posted by GoaterAz View Post
PM Sent!
Old 06-03-2016, 11:36 PM   #49
Captainfab
60-66 Nut
I would like to hear fitment feedback from anyone that has installed this conversion on a '69-'72. Thanks
Old 08-08-2016, 12:57 AM   #50
Captainfab
60-66 Nut
I will be on vacation from 08-08-16 thru 08-25-16. If you wish to make a purchase you can post here in this for sale thread, send me a PM or an email to captainfab454@hotmail.com. I will reply to your inquiry when I return on the 25th. I do currently have a list of orders to build and ship when I return but I will add your name to the list in order of when received. Thanks for your understanding.
