09-13-2015, 01:42 PM | #401 |
Second Chance Program
Re: My 78 K15 High Sierra build - Fish Tremble
No big deal to swap axles later down the road. Do some soul searching and try to figure out exactly how you will be using these vehicles in real life. Not how you imagine or would like to, but how you will really use them in reality. Mostly city driving? 4.10s and nv4500. Cruising? 3.07 and 465.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
09-13-2015, 03:15 PM | #402 | |
Yep, have 3. They are 28, 29 and 30 years old.
BTW, your truck is looking good in primer!
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
09-14-2015, 02:46 AM | #403 |
My 3.07 work well with a 6.0 2x4 but I would imagine the 4.10 would be more "fun" but may take the practicality out of driving it every day.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
09-14-2015, 10:02 AM | #404 |
Geesh that's a tough one. What would be perfect is the nv4500 and a set of 3.73s and 33s. I kinda think if it was me I would just stick with the 3.07s and 465 in the gmc and do the 4.10s and nv4500 in the other truck as long as you are for sure going to get to the other truck project fairly soon. If the other truck won't be on the road for a few years still, I would stick the nv4500 in the gmc with the 3.07s and save up for a 3.73 gear swap. Or even just a used set of 3.73 axles that you could freshen up and toss under it.
09-14-2015, 10:05 AM | #405 |
I guess I'm kinda thinking of it this way, the nv4500 in od with the 4.10 will be roughly the same as the 465 and 3.07s for highway cruising. The difference being the around town stop and go kind of stuff. Taking off with the 3.07s will be a lame lug fest from every light. The flip side is with the nv4500 and 4.10s, I don't know that there will be a perfect "1st" gear for taking off from stop lights with it either.
09-14-2015, 10:50 PM | #406 |
Appreciate the feedback guys. you've hit on my dilemna. I have had a truck with 4.10 but auto and it was great in town or on the road. But I think I am leaning toward just sticking with what's in there until I have a chance to drive it a while. But I know I will kick myself later if I decide I'd rather have the overdrive and could have swapped now when it would be much easier.
Next dilemna. Need to put chassis on stands, pull wheels, remove tires and paint rims. Chassis would be in the way of setting up paint booth while on stands. Do that before or after painting the rest of the truck? Will be a disappointing look to see those maroon rims when i reassemble the painted truck, but a couple week delay (at my rate of progress) on getting started with painting the truck if I do wheels first. I'd hate to have a "meh" reaction to seeing my truck going together with color, so I'm thinking I'll take the delay and do the rims first.
09-15-2015, 12:54 PM | #407 |
I have the same problem with the wheels. But I have decided to just accept that it will look a little poopy until I get the new wheels and tires after the first of the year. Also saves me from having to worry about getting any paint on them in the mean time!
09-15-2015, 12:55 PM | #408 |
Also, because this is my first paint job, I'm willing to accept a slightly meh outcome as long as I learn a good bit along the way so that each subsequent paint job will turn out better and better.
09-15-2015, 10:38 PM | #409 |
I think we are both going to be very satisfied with our first paint jobs y5mgisi (I always have to go back to make sure I got your username right ) because we've both taken the time to do our research and we'll be making a real effort to get it right. Still not sure about assembling a brown truck with maroon wheels though
09-16-2015, 07:32 AM | #410 |
I'm envious. I wish i would have painted mine. I am sure you'll be pleased with
your own work. Besides, not waiting on a body shop, being told lies, delayed, not knowing if they did it right and on and on and on and on are things you don't have to worry about. Good luck to ya on laying down some color. I can't wait to see it. Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! |
09-23-2015, 08:31 PM | #411 |
Well, a bit of an update. Did not make it to the paint shop this weekend, so pulled the wheels. Took them to town and got the tires removed. Then blasted them with Black Diamond from TSC. Had not tried this stuff before and I think what I got was a bit too coarse. It doesn't create much dust and is supposed to be safer than sand from the standpoint of what you might inhale. Worked ok, but the dang stuff ricochets everywhere and cleanup took quite a while. They did have another stack of bags that was probably the finer grit, but what did I know? Any case, boring picture of the truck ralley's before and after blasting. They will still need some final sanding and cleanup.
09-23-2015, 08:38 PM | #412 |
But a bit more interesting update as well. Tonight, I did get off work early enough to make it to the paint store. Got some epoxy primer/sealer and a couple ounces of my base color to sample. Also got the top of the line clear coat with the best UV protection (from what I was told) so that the paint job would last. Sprayed the paint card when I got home, but it was too late to get a good look in the sunlight. I did see the color on the inside of the lid in sunlight and I think that it is just what I was expecting. Obviously need to figure out how to dial in the gun for paint as that looks pretty grainy on the card.
09-24-2015, 12:27 AM | #413 |
Looking forward to the color chapter! Keeper up, almost there.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
09-24-2015, 07:19 AM | #414 |
Me likey!
Pardon me if you already said this, but are you going to make a booth to do the spraying? can't wait to see some color. Chris
09-24-2015, 06:57 PM | #415 |
Thanks bilfman and Chris! It shouldn't be long now, but since I pulled the wheels I've got to get them painted and rubber on them to make my chassis a roller again. It is right in the way of where I'd have to put together a booth. I've also got to wire a couple more lights in that space so I can see what I'm doing. So, other than the wheels, it may still be a few weeks before I can put color on the sheet metal. Slowly but surely though...
09-28-2015, 10:27 AM | #416 |
Well, I'm convinced I picked the hardest part of the truck to try painting first. Getting even coverage down deep in the wheels was a little tough, but I think that they came out real well. I just painted them on the floor in the open garage doorway, and was losing my natural light by the time I was trying to finish the outside of the wheels. Looked at them on my way out to work this morning and don't see any bare spots, runs, sags, bugs or even dust nibs. But it's overcast and I'll reserve judgement until I can see them in full daylight. I also can't wait to see this color in full sunlight! Looks great in the artificial light. Anyway, most of the weekend getting the wheels ready for paint, then epoxy primer/sealer, couple coats of color and a couple coats of clear. I think flat panels will be easy compared to these.
09-28-2015, 06:15 PM | #417 |
The wheels look really good. The hard part is mounting tires on painted wheels. Hope you have a good shop near you. I thinking about painting my wheel too.
09-28-2015, 06:28 PM | #418 |
Thanks dwilber. These had already been painted before. I liked having the body color on the wheels, so that's what I'm doing here. I am hoping that mounting the tires doesn't cause any damage that the chrome beauty rings won't hide.
09-29-2015, 12:55 AM | #419 |
The beauty rings should hide any damage that may occur!
09-29-2015, 09:47 AM | #420 |
Loving that color. What did you ultimately choose? It's a lot easier to see than mine.
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! Last edited by cmabolt; 09-30-2015 at 08:56 AM. |
09-29-2015, 10:30 AM | #421 |
Looks nice!
09-29-2015, 11:43 AM | #422 |
Thanks guys. Chris, this is the 1980 GM Dark Camel color, but I asked the guy mixing the paint to add a little more of the copper flecks to make it a bit brighter. Hoping that it will pop in the sunlight.
09-29-2015, 12:19 PM | #423 |
Really diggin' the color, great job laying out the paint on the rims.
09-30-2015, 08:53 AM | #424 | |
Chris
09-30-2015, 10:22 AM | #425 | ||
