Old 09-14-2015, 12:02 PM   #1
68basket
Big block vs small block engine stand
I am putting an ls1 into a 71 gmc blazer. Originally a 6cyl 3ott.
My customer provided mounts. Cpp sliders, Cpp BIG BLOCK sheet metal stands, and a cpp tube trans cross member.
My question is whats the difference in bic block vs small block stands? which one sits lower or taller?
68basket is offline   Reply With Quote
Old 09-14-2015, 01:44 PM   #2
Matt Cramer
Re: Big block vs small block engine stand
The big block stands have more exhaust clearance.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 09-14-2015, 02:22 PM   #3
68basket
They do look like they have plenty of room for exhaust. But it seems like the engine is sitting too high. I am trying to find out if the big block mounts make the engine sit higher than the small block mounts would.
Old 09-14-2015, 06:33 PM   #4
crazy longhorn
Fabricate till you "puke"
Yes, the BB stands do set the engine a little taller in front. If you can get the drive line angles right, I would not worry about it? longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-14-2015, 08:15 PM   #5
68basket
Looks like I will need a pretty big spacer at the trans mount to line it up. Do you know how much taller the big block stands are?
