Old 09-14-2015, 05:27 PM   #1
71c20junkie
71c20junkie's Avatar
bbc or sbc
im contemplating either going bbc or sbc i have both just not sure which way to go 3 speed trans eaton ho52 rear i want torque for towing and power for going down the road whats yalls advice
71c20junkie is offline   Reply With Quote
Old 09-14-2015, 05:39 PM   #2
3drburb
Re: bbc or sbc
Big block done right will also need some up front suspension work. If torque and heavy towing then big block gets my vote.
3drburb is offline   Reply With Quote
Old 09-14-2015, 06:26 PM   #3
summitflier
summitflier's Avatar
Re: bbc or sbc
If you want torque AND power... I would go big block.
You can get a lot of power from a small block, but it's difficult
to match the torque, especially at lower RPMs.
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline   Reply With Quote
Old 09-14-2015, 08:13 PM   #4
mike16
Re: bbc or sbc
whats the gearing in the rear end. thats what determines the usable range of torque and power. I have a 72 c10 with a 307 3 speed on the column. and 373 gears in the rear it is not fast and I am always serching for that next gear. even if it were a bbc I'd still be searching for it.
But on the other hand I have towed some increadable loads, very slowly thanks to the 373 gears. I have though alot about going with highway gear set. but on those occasions when I haul thos crazy heavy loads I am always greatfull for those 373 gears.
Too bad its a 3 speed because I am so bias in favor of three speeds, especialy if they are all origonal. if not... then you might consider a NP 4500 s speed overdrive tranny install befor you go with a BBC or sbc swap. cheeper all around and it really changes the personality of the truck, especially if you do highway driving.
all that being said, I find the small block gets the job done more cost effectively. BBC is kinda overkill 90% of the time.
mike16 is offline   Reply With Quote
Old 09-14-2015, 08:20 PM   #5
71c20junkie
Re: bbc or sbc
It had an Eaton h052 rear with 410s I believe like I said I have the stock 350 and the 468 big block
Old 09-14-2015, 08:22 PM   #6
NoNeck
NoNeck's Avatar
Re: bbc or sbc
My vote... Big Block. Mainly because they looks awesome between the frame rails.
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 09-14-2015, 08:25 PM   #7
71c20junkie
Re: bbc or sbc
Dam that looks good I might try the big block them go from there I'm doing a frame off resto
Old 09-14-2015, 08:26 PM   #8
71c20junkie
Re: bbc or sbc
What kind of mods do y'all have if your running big blocks
Old 09-14-2015, 09:14 PM   #9
CST10
CST10's Avatar
Re: bbc or sbc
I vote big block. Low end tire shredding torque.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
