Anybody know what this is??
Hey guys, anybody know what this bracket is for?? The screwdriver is pointing at it in the pic. Also, the wire running down the right side of the tranny tunnel???
60 K20, eaton HO52, T221, SM420, Dana 44 closed 78 K20 Burb, 14 bolt, NP205, SM465, Dana 44 open 05 Dodge Ram 2500 5.9 Cummins 4x4 |
Re: Anybody know what this is??
Another pic
Nobody knows what this bracket is for??? Any possible guesses? I was yanking the blue shag carpet out after removing the seat and found the bracket and it was not hooked to anything but looks factory. The truck is a 78 K20 burb.
Is it welded to the floor?
If so - it's not factory. If it was welded it would have been attached in the body shop - prior to paint - and would have been painted body color along with the rest of the cab. I don't recognize it. Can you take a closer picture of the first view? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Yeah it don't look factory and it looks new to me.I have no idea what is it.
The wire is probably for the 4x4 indicator on the dash it should go under the shifter boot for transfer case to a sensor on top of case on np205 and to the shifter on a np203 my 79 k5 had it but I don't remember what gauge it was under originally fuel or speedometer I moved the indicators around when I installed the camaro tach
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
You need to post a better picture
When I pulled the carpet out of the truck, that bracket was under the it. I'll get better pics when I get back from the field. Thx
It definitely doesn't look original. It's stainless steel. No clue what it would be used for. Dang PO's and their monkey business
Another
I have no clue what it is or why its even there.
Remove it... it is not stock nor needed.
Only thing i can even think of its a ground for something they installed behide or under the seat like amp.
I was thinking a CB radio bracket? I agree definitely not stock. Trash it....
#15 |
Could you stuff a cb under the seat tho ?
#16 |
78K & 79C Jimmys
old mobile phone base?some had long goose necks
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
