Old 09-15-2015, 07:38 PM   #1
HULK64
How to cut 3600 bed to 3100
I ended up with a 3600 bed. I have searched on this forum and on Google with not a lot of luck on where to cut it down to make it a 3100. Help the dummy? My Google-fu is usually pretty strong. I'm disappointed in myself for asking, trust me.
Is it as simple as cutting 10" out of the front?
HULK64 is offline   Reply With Quote
Old 09-15-2015, 11:23 PM   #2
whitedog76
Re: How to cut 3600 bed to 3100
This may help
http://chevy.oldcarmanualproject.com...sto/52060.html
http://chevy.oldcarmanualproject.com...sto/52068.html
whitedog76 is offline   Reply With Quote
Old 09-15-2015, 11:35 PM   #3
HULK64
That's super helpful! So the distance from the rear bumper to the center line of hte wheel well is 41 7/16" on both of them. I just read a build where a guy thought about cutting 9" but went with 7" instead and was very happy with it. Better to cut less than too much!
Old 09-16-2015, 08:40 AM   #4
Hampshire
Hampshire's Avatar
...I don't think that would work. The difference from a 3100 to 3600 is 9-1/4". I first saw crossfire84's build thread and followed his method when we cut my frame. I'm done so you can check my build thread. too.
crossfire84's thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=530662
Hampshire is offline   Reply With Quote
Old 09-16-2015, 09:30 AM   #5
Hampshire
Hampshire's Avatar
Hope I was clear that that even though you are not doing a frame cut, the 9-1/4" measurement applies to the bed, also. ...9" off the front of the bed would probably work, but 7" would not be enough. Even so, after we had a 1/2 ton bed on a 1/2 ton length frame, we moved the rear axle back a little more then an inch to center the wheel in the fender opening. Many builders do this last bit.
Old 09-16-2015, 10:11 AM   #6
MARTINSR
MARTINSR's Avatar
All I know is when you go to cut it, don't cut that section out and re-weld it. Remove the stake pockets by drilling out the spot welds and then cut off what you want then plug weld the stake pocket back on.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 09-16-2015, 11:43 AM   #7
mr48chev
mr48chev's Avatar
Brian has a good point there. The spot welds cut out pretty easy with a spot weld cutter and it makes a lot better all around job of it.
There is a 9-1/4 inch wheelbase difference between the trucks but the difference in the length of the beds is 8-7/8 according to the GM herritage printout for the 53 models which have the best drawings.
You would want to cut the bed sides down pretty close to exact if you are planing on using a precut bed wood kit. A slight length adjustment to center the wheels and get the space between the back of the cab and the front of the bed just right (especially on a frame swap) wouldn't be a big deal if you cut your own wood for the bed.
https://www.gmheritagecenter.com/doc...olet-Truck.pdf
My ongoing truck projects:
Old 09-16-2015, 08:36 PM   #8
HULK64
I should clarify: I am using an S10 frame, so it sounds like 8 7/8" is the cut to make to the bed. No cuts to the frame. I will be making a custom bed floor- no kit.
So you are saying the stake pockets need to be moved so they are on the front edge of the bed? How many places is it spot welded?
Old 09-16-2015, 08:44 PM   #9
Coach529
Coach529's Avatar
Cutting a long bed down is pretty close to breaking a mirror, or having a black cat cross your path........
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 09-16-2015, 11:15 PM   #10
MARTINSR
MARTINSR's Avatar
Run a small grinder over it to see the welds. There are probably 20-30. Check out this "Basics of Basics" on the subject.
http://www.hotrodders.com/forum/basi...ls-222549.html
Brian
1948 Chevy pickup
