Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-13-2015, 12:09 AM   #1
Northwest Outlaw
Northwest Outlaw's Avatar
92 ignition electrical problem
Thanks for any help.
PROBLEM: No start, no crank. Nothing happens when the key is turned to "Start". When key turns to "On" the fuel pump spins up, dash lights and radio come on but when I turn to "Start", zip nada nothing! Radio dies but dash lights stay on.
TRUCK: 1992 s10 2.8L V6 5-speed manual, ext cab. At or around 200K miles.
ATTEMPTED FIXES: New starter solenoid. New Ignition Control Module. Battery tested and good. New battery bolts (side mount) and cleaned all battery connections to bare metal for best ground. New Ignition Switch. All fuses check out good. By-passed the clutch safety switch and no change.
Truck cranks and will even start and run if I gap the starter solenoid posts, so mechanically she wants to run. Something is happening between ignition switch and starter, but I'm at the end of my brian capacity on this one, and out of beers.
Thanks for any help and ideas.
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline   Reply With Quote
Old 09-18-2015, 05:58 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 92 ignition electrical problem
is there an ignition fuse or a fusible link like on the older trucks?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-18-2015, 06:08 PM   #3
Northwest Outlaw
the problem has been resolved. Apparently the ignition switch needs to be positioned in the right place to allow the key turn to fully engage the "crank" position in the switch. 1/8" towards the firewall and all is good, so far.
To your question, there is an ignition fuse on the fuse block.
