Old 09-19-2015, 02:43 AM   #26
blackbart63mule
blackbart63mule's Avatar
Re: Making Keys For The ’60 -‘66 Chevy Trucks
Thanks for info about the #'s stamped into the lock cylinder. LocDoc, are there different pins or wafers for the door cylinders that are more pick proof? I seem to remember reading in a locksmithing book about it. How hard would it be to key 3 lock cylinders alike for our panels or suburbans? Thx.......Dog
blackbart63mule is offline   Reply With Quote
Old 11-13-2015, 01:12 PM   #27
LockDoc
The Older Generation
LockDoc's Avatar
GM has used the Briggs & Stratton side bar lock since 1935 and because of it's design it is almost impossible to pick.
It's pretty easy to key the lock cylinders the same on the '60-'66 GM trucks.
LockDoc
Leon
Old 11-22-2015, 12:00 AM   #28
blackbart63mule
Thanks again for the info Lock Doc!
Old 11-22-2015, 10:44 AM   #29
65chevysub
65chevysub's Avatar
If you can, whats the cost of re-keying a Suburban tailgate lock to match the front doors? I replaced my tailgate lock on my 65 about a year ago with a new lock, but have a seperate key for it. It's a Briggs key. I'm trying to get down to just a few keys on my ring.
65chevysub is offline   Reply With Quote
Old 12-14-2015, 01:14 AM   #30
LockDoc
LockDoc's Avatar
It would run about 10 bucks plus shipping back to you.
LockDoc
Leon
Old 12-19-2015, 06:34 PM   #31
Jacobmaynard97
Could I get the code off my original ignition cylinder and have a key made, my 62 didn't have a key with it when I bought it, and I bought a new cylinder but I'd like to keep the original in it
Jacobmaynard97 is offline   Reply With Quote
Old 12-20-2015, 10:32 AM   #32
65chevysub
65chevysub's Avatar
LockDoc
Thanks LockDoc
I'll try to get my back door and 2 front door locks to you after the first of the year when everything settles down after the holidays. I need the fronts re-done as I'm still using the ORIGINAL key and it's pretty well worn.
Old 12-20-2015, 05:14 PM   #33
Joemomma1
Joemomma1's Avatar
So do you match locks with keys? Over time I've managed to get everything mixed and would like it all to work with 1 key again.
Joemomma1 is offline   Reply With Quote
Old 03-15-2019, 06:50 PM   #34
DakotaKid
is there a way to make the Door key match the Ignition Key?
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 03-25-2019, 11:39 AM   #35
LockDoc
LockDoc's Avatar
Yes, either the door lock/locks can be re-keyed or the ignition lock can be re-keyed to match the other.
LockDoc
Leon
Old 04-18-2019, 08:18 AM   #36
cff
Active Member
Hi LockDoc. What do you need to rekey the ignition and door lock to match?
cff is offline   Reply With Quote
Old 04-18-2019, 09:15 PM   #37
Johns 66
Johns 66's Avatar
Wanted to post in this thread....Mr Leon rebuilt my door locks and re-keyed a glove box lock for me. He also cut me 2 keys from original blanks. If you are considering having this done I would highly suggest using Mr, Leon.....He did an awesome job for me, quickly and everything works perfectly. I really appreciate it a lot Mr Leon.
John
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline   Reply With Quote
Old 04-20-2019, 12:54 PM   #38
LockDoc
LockDoc's Avatar
Do you have a key for either of the locks? If you have a key for one of them all I would need is the key and the lock that needs to be changed. To re-key one lock would be $12.50US + postage back to you. Postage is higher to Canada from the US.
Thanks,
LockDoc
John
Thanks for the kind words John. Glad you were happy with the locks and my work.
Leon
Old 05-05-2019, 09:15 PM   #39
oliver63
oliver63's Avatar
I have a '63 C10...the door and glove compartment are one key and the ignition is a separate key. Was my truck a one key or two key originally?
1990 Silverado Sport
2010 Silverado K1500
1996 K2500
oliver63 is offline   Reply With Quote
Old 05-07-2019, 10:14 AM   #40
LockDoc
LockDoc's Avatar
One key would have fit all of the locks from the factory. I'm betting someone changed the ignition cylinder. I can re-key the ignition to match the door and glove box if you ever decide to go that way.
LockDoc
Leon
Old 05-07-2019, 03:04 PM   #41
oliver63
oliver63's Avatar
LockDoc
thank you Leon...I would like to re-key the ignition cylinder. I am going to try to find a extra cylinder to send to you so I can keep this one. I'll get in touch with you when I find a extra one.
1996 K2500
Old 05-08-2019, 12:12 AM   #42
LockDoc
LockDoc's Avatar
Which style cylinder is in your truck the flat one or the one with ears?
LockDoc
Leon
Old 05-08-2019, 07:58 AM   #43
oliver63
oliver63's Avatar
LockDoc
it has the one with ears...
1996 K2500
Old 05-09-2019, 12:04 AM   #44
LockDoc
LockDoc's Avatar
I have some of those on hand, both new and good used, when you get ready.
LockDoc
Leon
Old 05-09-2019, 03:27 PM   #45
oliver63
oliver63's Avatar
LockDoc
pm sent
1996 K2500
Old 05-13-2019, 12:57 PM   #46
oliver63
oliver63's Avatar
Thank you Leon...I received the ignition cylinder and keys today. Everything fit and looked great. Thank you for your fast help.
1996 K2500
Old 05-16-2019, 11:21 AM   #47
LockDoc
LockDoc's Avatar
No problem. Thanks.
LockDoc
Leon
Old 05-16-2019, 06:25 PM   #48
roll_the_dice
roll_the_dice's Avatar
My ignition cylinder and door lock are both worn out and can be turned with a screwdriver without any effort. Can you rebuild them...also if I wanted a door lock on the passenger side, do you have any cylinders that can be put in there? PM me an estimate or answer here and we can get the ball rolling. Thanks!
roll_the_dice is offline   Reply With Quote
Old 05-17-2019, 12:44 PM   #49
LockDoc
LockDoc's Avatar
Yes, I can rebuild the cylinders if they are not damaged on the inside from using a screwdriver on them.
PM sent.
LockDoc
Leon
Old 05-17-2019, 08:43 PM   #50
LockDoc
LockDoc's Avatar
Pictures of 2 different styles of OEM GM Octagon head key blanks. The first one is the older style with the code knockout, manufactured from 1935 - 1966 (to early '68 for trucks). The second picture is the later manufactured blank with no code knockout in place. They are still being manufactured today.
LockDoc
Leon
