Old 09-23-2015, 12:08 PM   #1
troutin55
troutin55's Avatar
Temp Sensor install help - New Champion radiator
Just bought a 4 core Champion radiator with electric fan thanks to the help of this fine forum. I'm trying to find the best spot for the temp sensor. After some research online, looks like I could use one of the ports on the intake, or the water pump. Problem is both ports on the intake are already taken, and the water pump has a bunch of hoses for the heater, which I don't want anyway. What should I do here? I already have my heater delete plates, should I just remove the heater and all the hoses, use one of the ports that will be freed up by removing the heater, and cap the rest? Thanks for the help.
troutin55 is offline   Reply With Quote
Old 09-23-2015, 12:32 PM   #2
morethanstock66
morethanstock66's Avatar
Re: Temp Sensor install help - New Champion radiator
You might consider using a water outlet that has a bung, or two, in it for a sensor. That gives you another, or possibly 2 other port options. That is what I always used.
http://www.oreillyauto.com/site/c/de...0420&ppt=C0331
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 09-23-2015, 12:41 PM   #3
DLW
Maybe try something like this http://67-72chevytrucks.com/vboard/s...d.php?t=483452
There is also complete replacement thermostats with ports built in. I wouldn't use the heater ports for accurate temp.
DLW is offline   Reply With Quote
Old 09-23-2015, 01:12 PM   #4
troutin55
troutin55's Avatar
Thanks guys, ended up buying this on ebay, $22
Old 09-23-2015, 05:21 PM   #5
craiginaustin
craiginaustin's Avatar
You should also have a spot on each head where you could put a sensor.
craiginaustin is offline   Reply With Quote
Old 09-23-2015, 06:43 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
I believe the cylinder head outlet is where the heat sensor for the radiator is supposed to be mounted.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-23-2015, 07:19 PM   #7
rcnutt
rcnutt's Avatar
Driver side in the head
rcnutt is offline   Reply With Quote
Old 09-24-2015, 12:20 AM   #8
Captainfab
60-66 Nut
I agree. However the pipe plugs in those locations can be a bit of a pain to get out if they have not been removed for a while.
