Old 09-24-2015, 04:16 PM   #1
Ronw435
Ronw435's Avatar
318 Transmissions
Does anyone know if all the 318 chevy 3 speed transmissions have the same output shaft?
Ron
Ronw435 is offline   Reply With Quote
Old 09-24-2015, 09:19 PM   #2
cv65
cv65's Avatar
Re: 318 Transmissions
are you refering to splines or length? some {trucks} have short tailshafts,{cars} long tail shafts
cv65 is offline   Reply With Quote
Old 09-25-2015, 07:41 AM   #3
Ronw435
Ronw435's Avatar
Yes CV65 I was talking about the splines.
Old 09-25-2015, 09:29 AM   #4
cv65
cv65's Avatar
as far as I know they were all wide spline not like the automatic or saginaw 3speed w/syncros ,I maybe wrong ,hopefully somebody with more info will chime in.
Old 09-25-2015, 10:31 AM   #5
MikeN
MikeN's Avatar
I learned the hard way that they don't all have the same diameter bearing retainer on the front. The 318 in my truck crapped out, and I bought what I thought was an identical one at a swap meet. Apparently the one I bought was out of a passenger car. The bearing retainer diameter was smaller on the 318 I bought, so it didn't fit tightly into the hole in the bellhousing as it should. It was at least 1/4" smaller.
MikeN is offline   Reply With Quote
Old 09-25-2015, 03:15 PM   #6
Ronw435
Ronw435's Avatar
I read where you can take the one off your transmission and use it on the other one, is that not correct?
Old 09-25-2015, 03:17 PM   #7
Ronw435
Ronw435's Avatar
Does anyone know what you can use as a intermediate shaft for the cluster gear to be able to install new bearings? It has to be shorter than the original one I believe or you cannot get the cluster gear in.
Ron
Old 09-25-2015, 08:29 PM   #8
MikeN
MikeN's Avatar
I believe so, yes.
