Old 09-24-2015, 07:22 PM   #1
sharkskinman
65 c10 rear U bolt measurement
cant find 5-6" drop block kits so im going to make my own like i have many times before
can someone give me measurements for the Stock Rear U Bolts so i can get some extended ones made
OR
can someone measure the ones on a 4" drop block kit if someone has them installed
sharkskinman is offline   Reply With Quote
Old 09-25-2015, 07:02 AM   #2
PGSigns
PGSigns's Avatar
Re: 65 c10 rear U bolt measurement
Issue with the blocks being that tall is the design of the trailing arms. The angle is tilted up and when you put a block on it it moves the rear end forward. The rears in these trucks are already forward in the wheel well and a block that size would move it an inch further forward. Also a block bigger than about 2" caused scrub line problems. A block that size would be a big issue with a 15" wheel.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-10-2022, 01:46 AM   #3
spspspspoon
Let's see if I can get an answer
I never did anything to my rear and today very quickly apparently
There is now a space between my axle and the trailing arms at the u-bolt
Almost looks like there should be some sort of rubber or spacer or wedge
I do see a little bit where on the bolts due to the I guess trailing arms rubbing on it back and forth
I do not see that any of the bolts have come loose I don't see any cracks or breakage in the u-bolts
But damn it if I don't have space a good eighth of an inch to a quarter of an inch
It seems that however it's happening it has happened fairly quickly
I've never dealt with that sort of noise or movement in my truck until very recently
Where can I get those u-bolts and does anybody have an idea on why there would be a space
spspspspoon is offline   Reply With Quote
Old 09-10-2022, 09:32 AM   #4
ACK
ACK's Avatar
Where the u-bolt goes through the trailing arm, a lot of crud gets inside there and it's possible the bolt failed in there, the crud held it tightly in place until it didn't, and now it's broken free. You can find u-bolts on the web, maybe locally, too, if you're lucky. Here's some links:
https://www.holley.com/products/susp...s/parts/UBOLTS
https://www.performanceonline.com/19...n-C10-and-C20/
https://westernchassis.com/1960-1972...Arm-Ubolt-Kit/
Seriously, that crud will lock the bolts in place, don't be surprised if you need to bash them out, then ream the crud out to get the new ones in. Give the trailing arms a good look over afterwards, if they fail while driving, you could end up in a bad place. How's the trailing arm bushings? If they haven't been changed out, might want to do them as well. They're a pain to replace, but worth it if you have the time. Same with the coil spring retainers.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 09-10-2022, 10:10 AM   #5
cwcarpenter98
cwcarpenter98's Avatar
Sounds like the u bolt broke or wasn't tightened to the proper torque by the previous owner. The axle does not sit on a spacer or wedge at stock height, just flat on the trailing arm. No rubber either. If the bolts have wear on them, replace them.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-13-2022, 09:40 AM   #6
spspspspoon
In those links is 2 Different Sizes
So??
Old 09-13-2022, 12:34 PM   #7
spspspspoon
Have found two places I can get them made.
one needs a u-bolt one doesn't need the u-bolt
can anybody please take me an actual measurement
Mines a late 65 with trailing arms and 3/4-16 u-bolts
I don't have my truck in front of me and I haven't had it in front of me in a couple days so I can't take a measuring myself
Most of the ones that I see say 3 wide some say 3 1/2??
Old 09-15-2022, 07:58 PM   #8
spspspspoon
So it was a wearing of the holes in the axle cradle
The holes got wallowed out and has allowed the U-Bolts to shift on the axle.
Subsequently allowing it to get tighter and looser as I drove it
Can anybody give me an inside measurement of the welded on cradles
Wanting to use some flat steel w(w/3/4" hole) to make some inserts(washers?)to weld into them
