Old 02-19-2004, 04:34 PM   #1
jamesjones
Freakin Awesome!
jamesjones's Avatar
TH400/205 Q's?
A friend of mine got ahold of a TH400/205 combo about of I believe an 85' chevy. Will I have any problems hooking this combo up to the 350 and GM 12 Bolt axle in my 72 Blazer? Any info is much appreciated.
James
jamesjones is offline   Reply With Quote
Old 02-19-2004, 05:46 PM   #2
NAPCO ken
NAPCO ken's Avatar
Yep, you'll have all kinds of problems. Best to just sell that set-up to me!!! (J/K). Actually you will have zero problems bolting that thing right up.
ken
'58 Chev NAPCO 4x4 short
'60 GMC Suburban 4x4, restored
'60 GMC 3/4T stepside 4x4
'64 GMC Suburban 4x4, restored
'90 Chev Suburban 4x4, dually, ZZ502
'77 GMC Suburban 4x4, one ton axles, 12" lift, 39.5"s
'88 Chevy crewcab dually 4x4, 10" lift, 42"s (x6!)
'03 Jeep Wrangler Rubicon
'79 Chev 3/4 Suburban 4x4, 400-400-203
NAPCO ken is offline   Reply With Quote
Old 02-19-2004, 06:20 PM   #3
jamesjones
Freakin Awesome!
jamesjones's Avatar
Awesome. Thanks for the reply. I'm getting ready to stroke the 350 in my Blazer to 391 and knew that the stock TH350 wouldn't last. When I asked around at some local Tranny shops they made it seem like a huge deal to swap the TH350 for a TH400 and keep the 205. This way I can buy the TH400 and 205 already hooked up. I'll be selling my stock TH350/205 combo if you're interested.
James
Old 02-19-2004, 07:51 PM   #4
NAPCO ken
NAPCO ken's Avatar
Well, it is a huge deal if you just have a turbo 400 and want to convert it to wrok with your 350's 205. That requires expensive adapters. The best way is the way you did it, all combined already. Much cheaper in the long run.
Also, how much do you want for the 350/205 when you're done?
ken
Old 02-19-2004, 10:21 PM   #5
jamesjones
Freakin Awesome!
jamesjones's Avatar
Shoot. I have no idea what it's worth. I'll probably let it go cheap though. As soon as I get the swap done I'll let you know.
James
Old 02-20-2004, 04:19 AM   #6
1tonswb
1tonswb's Avatar
Your gonna have to redrill the holes on the frame to move the crossmember back to compensate for the longer t400. Also the front driveshaft is gonna have to be lenghted and the rear driveshaft shortened (assuming the 205 has a bolt on yoke and not a slip shaft). If it does have a slip shaft then your gonna need a new driveshaft for the rear or convert your 205 to a bolt on yoke style. If you still have the t-case brace on the frame then your gonna have to move that back also. The rest is pretty much a bolt in.
1tonswb is offline   Reply With Quote
