Old 09-28-2015, 09:40 AM   #1
Copperman
Copperman's Avatar
70 C10 drop 4/2
Hi all,
Been on this site for years but don't post much. So much great info here. I wanted to post up my drop. My truck had 22's on it and I rode on them for years and hated them. I bought 4/2 drop springs, drop shocks for the front and adjustable air shocks for the rear. I haul some heavy stuff from time to time. My goal was to level the truck and bring it down a bit.
I started with 17x8 wheels and 255/60-17 tires all around. The rear came down 4" nicely and was straight forward. The only problems I had was my pipes came down on my diff so I had them rerouted. You can see the adjustable panhard bar I made in this pic as well. I ratchet strapped the axle over to center it up and cut/tacked my panhard bar. It moved a bit when the strap was removed so I made the adjustable one. I sleeved a 5/8" bolt to the bar and coupling nut. Worked great.
Replaced the springs in the front by removing the U-bolts and replaced the shocks. To my surprise I already had 2" drop springs and was not happy. So I replaced them with 4" springs to get my 2" drop.
It sit's nice now and drives and handles great.
Matt
1970 C10
Copperman is offline   Reply With Quote
Old 09-28-2015, 11:20 AM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: 70 C10 drop 4/2
Nice work and good looking truck - thanks for sharing!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 09-29-2015, 08:59 PM   #3
picklito
Re: 70 C10 drop 4/2
Nice write-up. I like how the panhard bar ended up almost parallel to the axle. I'll be doing the same very soon, but only about 2/4 total. Whose springs did you use? Do you like the spring rates?
picklito is offline   Reply With Quote
Old 10-01-2015, 09:36 AM   #4
Copperman
Copperman's Avatar
Re: 70 C10 drop 4/2
I originally bought DJM all around but since I needed 4" up front and DJM only has a 2" and 3" I had to put Hotchkis up front.
My ride is like night and day. Much smoother and doesn't handle like a semi truck anymore. I am really happy and its fun to drive.
Matt
1970 C10
Old 10-01-2015, 12:02 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 70 C10 drop 4/2
You might want to invest in rear shock relocators.
Look how severe your rear "shock angle'' is.
They no longer compress,... they just pivot on the shock bolts,...
Keith
Convert to disc brakes.
Old 10-05-2015, 12:19 AM   #6
Mmorgan32
Mmorgan32's Avatar
Re: 70 C10 drop 4/2
Where did you get the hotchkis 4" springs?
1972 gmc c15 short bed... Sold
1970 chevy custom camper patina daily driver
Mmorgan32 is offline   Reply With Quote
Old 10-05-2015, 10:27 AM   #7
Copperman
Copperman's Avatar
Re: 70 C10 drop 4/2
I got everything from Summit
Matt
1970 C10
Old 10-05-2015, 03:21 PM   #8
Mmorgan32
Mmorgan32's Avatar
Re: 70 C10 drop 4/2
Did u have any problems getting it aligned after doing a 4 inch drop?
Old 10-05-2015, 03:46 PM   #9
Slow Build
Slow Build's Avatar
Re: 70 C10 drop 4/2
Looking at your truck I would never have guessed that it's even lowered. It's hard to believe that it's still sitting that high in front with 4" drop springs.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 10-05-2015, 04:11 PM   #10
Copperman
Copperman's Avatar
Re: 70 C10 drop 4/2
AGREED! It put me on my heels a bit when I was planning this out.
Matt
1970 C10
