Old 09-30-2015, 11:45 PM   #1
Fredthecat
'64-66 tachometer
What tachometer can be adapted/retrofitted into '64-66 instrument cluster, right side?
What after market tach has been used with reproduction instrument decals?
Got this thing out and apart, might as well fill the holes.
Thanks, Fredthecat
Fredthecat is offline   Reply With Quote
Old 10-01-2015, 06:55 AM   #2
PGSigns
PGSigns's Avatar
Re: '64-66 tachometer
I have an older sun tach in mine that I pulled out the can. Almost a bolt in. Bosch is reproducing it now in a 8K model and I have been tempted to buy one and take it apart.
Jimmy
Amazon.com: Bosch SP0F000063 3-3/8" Retro... Amazon.com: Bosch SP0F000063 3-3/8" Retro...
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-01-2015, 08:28 AM   #3
corvettejim1968
corvettejim1968's Avatar
also if you dont mind spending the $225 you can buy the correct reproduction tach.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 10-01-2015, 10:07 AM   #4
TJ's Chevy
TJ's Chevy's Avatar
That tach only works for V8's according to All reproduction companies I've looked it up on. If you have a V8 that'll work fine.
Old 10-01-2015, 12:17 PM   #5
pimpston65
pimpston65's Avatar
i found a sun tach that was setup for a inline 6 and just took the shell off, oh it came with the box thing that can be used on 6 or 8cyl
pimpston65 is offline   Reply With Quote
Old 10-01-2015, 12:19 PM   #6
pimpston65
pimpston65's Avatar
of course it was nos and cheap!!! oh the box is call a transmitter...
Old 10-01-2015, 01:17 PM   #7
Fredthecat
Thanks for info.
Yeah, not so much $225. Need to find one I can adapt and install with reproduction decal set.
Thank you, Fredthecat
