Old 10-02-2015, 10:30 AM   #1
Mobius
C20 wheel fit?
I have a 77 C20. My friends dad has the factory wheels from a 2005 Chevy Duramax. I know the bolt pattern is the same, but how is fitment as far as offset and hub diameter? Will they fit ok, or will the offset/backspace be way off?
Mobius is offline   Reply With Quote
Old 10-02-2015, 11:18 AM   #2
83GMCK2500
Re: C20 wheel fit?
They look pretty good, particularly on 2wd trucks. You might be able to do a search for some pics, they're commonly (incorrectly) referred to by their RPO. The correct RPO is PY0, but most type/say PYO ("oh" instead of "zero")
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 10-02-2015, 11:21 AM   #3
Mobius
Re: C20 wheel fit?
Thanks for the info. Do you know if the offset works well in my application? I don't want to buy them and drive a ways to pick them up, only to find they'll stick way out or rub badly. Also, the truck is stock now, but will probably get lowered a few inches in the future.
Old 10-02-2015, 11:23 AM   #4
toddoky
Re: C20 wheel fit?
They will install and look fine on the truck, but your options for tire sizes that you can run will be limited by their 6.5" width. I bought a set off of ebay last year and re-sold them once I determined they wouldn't be ideally suitable for the 265/75R 16 tires I wanted to run on my truck.
toddoky is offline   Reply With Quote
Old 10-02-2015, 11:40 AM   #5
Mobius
Re: C20 wheel fit?
Good to know. Thanks. I can get them cheap, with good tired already on them. The rest of my work will be coming slowly, so they may be just fine for me until I can decide on a final size after its lowered. I just desperately want to get rid of the stock white steel wheels.
Old 10-02-2015, 11:47 AM   #6
toddoky
Re: C20 wheel fit?
No problem. It seems I'm going the opposite direction than you on my 79' C-20...my Dad had the truck for many years and lowered it with Belltech drop spindles and butchered rear springs about 12 years ago. I've spend the last 6 months removing all of that and returning it to stock ride height. You don't need a set of drop spindles do you?
Old 10-02-2015, 11:49 AM   #7
Mobius
Re: C20 wheel fit?
Actually, I was planning on drop spindles. How much you want for them? And how much drop do they have?
Old 10-02-2015, 11:53 AM   #8
toddoky
I'd take $150 for them. They are in great shape, but the threaded caliper holes in the driver side spindle needs to have thread repair inserts installed as they became stripped.
Old 10-02-2015, 11:58 AM   #9
Mobius
Re: C20 wheel fit?
I'll consider it. I wasn't prepared to buy them right now, but that's a good price, since new ones seem to be over $400.
Old 10-02-2015, 12:08 PM   #10
toddoky
Re: C20 wheel fit?
Yes, they are expensive and Belltech doesn't even make the C20 drop spindles anymore.
Old 10-02-2015, 12:09 PM   #11
Mobius
Re: C20 wheel fit?
Not sure which brand I've seen, then. But I found some that are currently available. But yeah. Pricey.
Old 10-02-2015, 12:52 PM   #12
83GMCK2500
Re: C20 wheel fit?
Pictures on this site, user lsxponcho's Green Mile
Devin
New Daily, the '96
Old 10-02-2015, 03:29 PM   #13
1970pelle
1970pelle's Avatar
Re: C20 wheel fit?
I just bought a set of the RPO's taken off a 4X4 Chevy Duramax Diesel and they have 285/75R16 on them. Way to big for my truck of course. I haven't broke them down yet to see if there wider than the 4X2 wheels.
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
Old 10-02-2015, 04:43 PM   #14
83GMCK2500
Re: C20 wheel fit?
All of the PY0s are 16x6.5. The only wider wheel was the 6-spoke 16x7 on the 3500 SRW trucks, in that generation.
It's pretty common for owners to mount 285s on them. I don't care for the ballooned look it creates, but with the right pressure they wear decently.
Devin
New Daily, the '96
