Old 10-03-2015, 12:20 AM   #1
Kaptain Kadian
Kaptain Kadian's Avatar
electric fan thermostat location problem
Hello, I am in the middle of swapping out my old radiator with an aluminum one with dual electric fans. The issue I have come into is the threaded port on my new radiator is smaller than the 3/8 threaded temperature sender from my derale 16749 relay kit I bought. I am not positive what size the port is, buy my question is, should I try to find an adapter or find another temperature sender? I have read a lot about where to out the temperature sender and I think I want to leave it in the radiator. I saw where someone put the sender in the return house of the radiator. I don't know if that would be a good option either. Thanks
Kaptain Kadian is offline   Reply With Quote
Old 10-03-2015, 07:29 AM   #2
hamjet
hamjet's Avatar
Re: electric fan thermostat location problem
I put mine inline with the heater hose comming off the intake with a brass T. Works great!
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 10-03-2015, 11:40 PM   #3
Kaptain Kadian
I am beginning to think I got the wrong temperature sender unit. I checked the threaded port on the aluminum radiator, and it appears to be 3/8, but the sender unit appears to be 3/4. The box and instructions say that it is 3/8 but it measures 3/4 across. Anyone else install one of these derale 16749 relays?
Old 10-03-2015, 11:55 PM   #4
clemsonteg
https://mdmetric.com/tech/thddat19.htm
clemsonteg is offline   Reply With Quote
