Old 10-03-2015, 05:31 PM   #1
Mathew21
Mathew21's Avatar
Turn signal switch plug question (1966 C20)
I have a 1966 C20 with a Th400 column. I ordered a turn signal switch replacement but when it came it has a curved plug. My plug is flat. After checking five different vendors sites they all of them show the curved plug. I'm not sure if mine has been switched at one time or another or?
Mine is the top photo. The plug I received is the bottom one.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 10-03-2015, 08:14 PM   #2
Jurassic-1
Jurassic-1's Avatar
Re: Turn signal switch plug question (1966 C20)
Usually later model (73) and up used a flat plug. Most replacements for early trucks would give you a curved adapter that fit on the straight connector. I have not seen a straight connector on an early turn signal switch.
Jurassic-1 is offline   Reply With Quote
Old 10-04-2015, 01:33 PM   #3
factorystock
factorystock's Avatar
The top photo is not original to the truck, somebody did some rewiring work. The bottom is the original correct multi-plug.
factorystock is offline   Reply With Quote
Old 10-04-2015, 04:04 PM   #4
Mathew21
Mathew21's Avatar
I was kind of thinking that's what happened. The previous owner did replace the wire harness.
