Old 10-05-2015, 06:08 PM   #1
Brave71
Wilwood adj. prop valve
I want to install wilwood adjustable prop valve....I have disc drum now , can I use the same prop valve if I change to disc disc set up later on?
Brave71 is offline   Reply With Quote
Old 10-05-2015, 07:01 PM   #2
Fitz
Re: Wilwood adj. prop valve
Yes.
Fitz is offline   Reply With Quote
Old 10-05-2015, 10:18 PM   #3
jmlcolorado
I think that's the point to an adjustable prop valve, so it allows you to dial in different brake setups, right?
jmlcolorado is offline   Reply With Quote
Old 10-06-2015, 11:17 AM   #4
Fitz
So it would seem.
Old 10-06-2015, 04:07 PM   #5
67chevemall
67chevemall's Avatar
Depends what you buy, mine is set at 500 for the rear drums and the front is adjustable from 500 - 1000
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 10-06-2015, 08:13 PM   #6
Fitz
Most Wilwood prop valves are single inlet single outlet and connect to the rear brakes only.
Old 10-07-2015, 11:57 AM   #7
knomadd
knomadd's Avatar
Wilwood has an adjustable prop valve that has a dual inlet triple outlet... which I have on my 71. It will work for either disc/drum or disc/disc. The adjustment is only for the rear. You would probably need to make an adjustment (turn the dial) to that prop valve when you did the rear disc conversion.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
