Old 10-06-2015, 06:57 PM   #1
chevytruckguy70
Exploding oil filter
My 72 c20 350 is having trouble keeping oil down. It's throwing it out at a rate of 4 quarts in 5 sec of engine running. The oil filter blows it's seal and that's it.
This is the original engine but I just put a new oil pump, lifters, valve springs, rockers and a complete gasket redu.
It blows as soon as it starts. Is it possible the oil pump is causing this? I can't run it long enough to get a pressure reading at the gauge.
Any ideas?
Only Two...... Only two have laid down their lives for you, Jesus Christ and the American GI.
2007 Chevy 2500HD 4x4 Duramax
1970 Chevy K20 (SOLD)
1972 Chevy C15 (1/2 C10, 1/2 c20)
1970 Chevy C10 (parting out)
chevytruckguy70 is offline   Reply With Quote
Old 10-06-2015, 07:04 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Exploding oil filter
It sounds to me (I am no mechanic) that you are building up too much crankcase pressure. Do you have a working PCV valve? But, 4 quarts in 5 seconds is insane, I can't see the crankcase building that much pressure that quickly.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-06-2015, 07:08 PM   #3
john
member #16
john's Avatar
I would say the pressure relief valve is frozen or stuck in your oil pump.
john is offline   Reply With Quote
Old 10-06-2015, 07:14 PM   #4
swamp rat
swamp rat's Avatar
I tend to think you have blocked oil passage past the oil filter, reversed gasket somewhere..
One more thought but highly remote, you didn't accidently install 2 oil filter seals?
oil diagram: http://67-72chevytrucks.com/vboard/s...7&postcount=10
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-06-2015, 07:21 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Or... the wrong filter. Just checkin' to cover all the baeses...
Also... sometimes the old filter gasket will hang up and come apart from the filter and stick on the block and stay there. usually when cheap Fram filters are used. Then when you put your new filter on you have a filter gasket against another gasket...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 10-06-2015, 07:38 PM   #6
chevytruckguy70
I've tried two different types of oil filters. There are not any pcv valves on the truck right now. It's not a double oil filter gasket either. I have tried this three times now after trying new things. On my third gallon of oil.
I'm afraid it is probably an oil pump or gasket installed wrong. I've just never had this happen before.
Let the fun begin, I guess.
Anyone want to help?
Anyone?
Hello?
Old 10-06-2015, 07:51 PM   #7
vidman
vidman's Avatar
I once had a 1973 cj with a 304 v8 in it, it would blow out the oil filter seal every 2 months or so. found out the relief valve was stuck. after that was fixed no more oil on the ground
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 10-06-2015, 07:54 PM   #8
EARNHARDT#3
EARNHARDT#3's Avatar
I had a 1989 VW Jetta that would spit the oil filter gasket out. Ended up being the oil pump pressure relief valve was bad.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 10-06-2015, 07:55 PM   #9
chevytruckguy70
Is the relief valve part of the pump or located in the block?
Old 10-06-2015, 07:59 PM   #10
hugger6933
It is in the pump just chunk that one and get another oil pump
hugger6933 is offline   Reply With Quote
Old 10-06-2015, 08:03 PM   #11
Jrainman
Jrainman's Avatar
I Agree most likely your oil pump had a spring failure in the relief valve ,
the spring got jammed or worn out so the relief valve in your oil pump is stuck wide open and your pumping oil at the rate your top end cant handle over 70 psi
you might dry sump your oil pan and ruin your crank bearings , drop the oil pan replace the spring and ball before its to late
Jrainman is offline   Reply With Quote
Old 10-06-2015, 08:07 PM   #12
chevytruckguy70
It will not be started again until the pump is replaced.
Thanks guys.
Old 10-06-2015, 09:04 PM   #13
swamp rat
swamp rat's Avatar
You should always take the distributor out and prime the oil system with a drill and a priming shaft tool or long screwdriver with the handle cut off before starting to avoid a dry start, if ya havent i'd recomend doing so this time around after ya try replacing the oil pump.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-06-2015, 09:41 PM   #14
chevytruckguy70
I primed the system with a drill. But that doesn't have the rpm to blow the filter.
Old 10-06-2015, 10:17 PM   #15
NTIMID8R
NTIMID8R's Avatar
Were any of the valve springs or other parts that got replaced broken? Sounds like a blocked oil galley somewhere. A piece of crud or piece of old gasket material could have fallen into a galley when you had the intake off.
Yesterday is history, tomorrow is a mystery, today is a gift, that's why it's called "the present".
1971 Sierra Grande LWB, 350/TH350, Factory Air Lots, of future mods planned!!
NTIMID8R is offline   Reply With Quote
Old 10-06-2015, 10:56 PM   #16
swamp rat
swamp rat's Avatar
In case it was missed i posted this, not a great pic but may help to visulaize where you may find problems.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-07-2015, 07:11 AM   #17
chevytruckguy70
There weren't any broken springs and I was pretty careful with the gasket material. This is the original engine and hasn't been rebuilt. It was suprisingly clean inside, just a little crude in the corners of the head near the drains. Clogging oil ports is always a concern on these old engines but I have never had this before.
I'll drop the pan and check the pump out. There is plenty of oil at the rockers so I believe it is getting through most if not all of the engine.
It WOULD be my luck a new pump would be bad, that is normal around here.
Old 10-07-2015, 08:05 AM   #18
67 chevelle
67 chevelle's Avatar
The filter adapter is the relief valve , what the oil filter screws into its held in the block by 2 bolts , accessible with filter off , Id pull it and check or replace it , there is a screen part to it , might be clogged
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 10-07-2015, 08:13 AM   #19
chevytruckguy70
The last thing I did last night was to remove the adapter and clean it out. The relief valve was sticking a bit but seemed to work ok once I cleaned it out. There was some sludge in the bolt holes but not too bad. I put it all back together but again after only a few seconds it blew out again.
Is the relief valve on the adapter the only one or is there one in the pump? When I was cleaning the valve out I would have bet it was the issue or at least part of the issue. That should have relieved instead of blowing the gasket.
Old 10-07-2015, 04:29 PM   #20
john
member #16
john's Avatar
The main pressure relief valve is in the pump. The other one is just a filter relief valve. I helped a friend install a rebuilt 454 that had a new pump and it had a stuck pressure relief in it. Blew two filter gaskets, another new pump fixed it.
Old 10-07-2015, 05:02 PM   #21
chevytruckguy70
Looks like the route I'm going to take John. Thanks for the reply.
Now the question is do I pull the engine or fight it in the truck? I don't have the dog house on it so pulling is probably better.
Old 10-07-2015, 05:20 PM   #22
cooperhw
cooperhw's Avatar
I would probably just lift it a bit and change it in the truck. But I work mostly by myself except body/paint so whatever is easiest for you.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 10-07-2015, 07:28 PM   #23
Redline novdog
Redline novdog's Avatar
I'm in! I would suspect the oil filter adapter, but there have been several posts of oil pump over pressure. Didn't realize you could have to much oil pressure (to a point),I realize it is a hydraulic system.
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 10-07-2015, 08:37 PM   #24
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Like John said "The main pressure relief valve is in the pump. The other one is just a filter relief valve. " filter bypass relief valve is for a plugged oil filter which is for those that run Quacker Snake Oil and change it every ten years.
CaptRMW is offline   Reply With Quote
