Old 10-07-2015, 07:26 PM   #76
400/400
Re: Minnesota Daily Driver
Helped a fellow car guy get his new project home today.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 10-07-2015, 11:11 PM   #77
MTCK
MTCK's Avatar
Looking tough. How's it tow with the lift and lift springs in the rear?
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 10-08-2015, 07:59 PM   #78
400/400
Tows pretty good. The trailer is well balanced.
Old 01-01-2016, 01:47 PM   #79
400/400
Just did a 300+ mile trip to pick up an engine for another project. The old rig performed well. Forgot to take pics.
With the last few months of driving in warm and cold I I've found the electric choke to be a good improvement over the divorced.
Also noticed once I started using the heater that there was a a lot of air coming from the dash vents with floor selected. Turns out the plastic bracket the connects the vacuum actuator arm to the mode door broke. When the dash vents were selected it would pull the door fine but when floor was selected it wouldn't push the door closed. I was able to find the bracket online. Heater is working good now.
The only other update is the what looks to be the original steering box started leaking. So there's now a rebuilt box installed.
Old 01-01-2016, 01:56 PM   #80
400/400
Here's an action pic from last winter plowing one of the few snows we got.
Old 01-01-2016, 01:57 PM   #81
400/400
Here's one of both my squares parked nose to nose this summer.
Old 01-01-2016, 05:58 PM   #82
MTCK
MTCK's Avatar
Looking good! Did you have to do anything to your plow mount to work with that lift? What's the story on your '87? Looks pretty tall.
-Marcus
Project Plow Truck
Old 01-01-2016, 08:25 PM   #83
400/400
After the 4" lift the plow blade would easily trip. I like the clearance I had on the truck side from the plow mount to the ground so I didn't want to lower that. I ended up making some blocks that moved the pin holes up on the "A" frame 4". So now the "A" frame is parallel to the ground. So far it's been working well that way.
The '87 has 6" of lift and 33x12.5x15 tires. It's a hop to get up in the seat.
Old 01-01-2016, 11:27 PM   #84
MTCK
MTCK's Avatar
That makes sense. Few rungs down on the chain and the lift cylinder doesn't know.
-Marcus
Project Plow Truck
Old 01-03-2016, 03:22 PM   #85
400/400
Couple of interior updates. I added boat grab handles.
Old 01-03-2016, 03:24 PM   #86
400/400
Also swapped the steering wheel for one out of a late '80s/ early '90s. I think it gives a bit more room.
Old 01-03-2016, 04:54 PM   #87
MTCK
MTCK's Avatar
Looks good. I like the handles. The wife unit would be very happy with a couple of those.
I think you are right, our plow controls look identical.
-Marcus
Project Plow Truck
Old 01-04-2016, 08:14 PM   #88
400/400
I like the handles because they give you something else to grab on the drivers side. I made a habit of not grabbing the wheel as it's hard on the column so it was kind of a trick to hop in before the handles.
Old 01-04-2016, 08:17 PM   #89
400/400
Back to the build.
After fitting the doors it was time to install the rubber floor liner.
Old 01-04-2016, 08:23 PM   #90
400/400
Then I threw the seat it and started gathering parts to bring it to the body shop.
Old 01-04-2016, 08:29 PM   #91
MTCK
MTCK's Avatar
Solid work. Does Warn make the front receiver hitch you are using? You are answering all kinds of questions for me.
-Marcus
Project Plow Truck
Old 01-04-2016, 08:49 PM   #92
400/400
Thanks, Happy to help.
For the front receiver I bought a generic approximately 6" long 2" receiver tube and welded it to the plow frame. It put it just below the bumper and is plenty out of the way for the plow components.
Old 01-19-2016, 10:50 AM   #93
LF_MN_71GMC
LF_MN_71GMC's Avatar
Hello from Isanti,
This is great work, I'm waiting for a good snow to get my square out to plow for the first time. It has a 4" lift and I have not modified any of the A frame brackets, I hope it's not tippy.
1971 GMC 4x4 half ton np 205
1969 chevrolet camaro
1984 K10; 4" lift; sbc;
Build link
http://67-72chevytrucks.com/vboard/s...d.php?t=647172
LF_MN_71GMC is offline   Reply With Quote
Old 01-19-2016, 09:14 PM   #94
400/400
Originally Posted by LF_MN_71GMC View Post
Hello from Isanti,
Thanks. Yeah not much snow yet. If your plowing fresh snow the blade shouldn't be too tippy. It's worse when there's a layer that's already been driven on. I've only put it one once this year so far. May use it this weekend to clean up some drifting.
Old 01-19-2016, 09:17 PM   #95
400/400
Replaced the t-stat. Noticed the truck wasn't getting up to temp. Not a great thing when it's around 20 below.
Old 04-10-2016, 07:12 PM   #96
400/400
Not much new to report. Just been driving it daily. The good news is that I was able to find some more pictures.
Here's wire wheeling the frame.
Old 04-10-2016, 07:13 PM   #97
400/400
Here's the underside of the box painted.
Old 04-10-2016, 07:17 PM   #98
400/400
These show how much floor was replaced on the passenger side.
Old 04-10-2016, 07:28 PM   #99
400/400
And to continue on with the build, here's some pics from the body shop.
Old 04-10-2016, 07:30 PM   #100
400/400
This is the white on the roof and tailgate.
