Old 10-10-2015, 10:46 PM   #1
zplightning
Airbag Installation - Trac bar?
I tried searching, so my apologies if this is covered somewhere.
I am installing bags on my 1963 C-10, and have everything installed in the rear besides the trac bar (stock frame, no notch).
I bought a CPP adjustable trac bar (6364DATB) from summit, and it came only with the bar. When the truck is completely aired out, the trac bar is about 3-4" too long, and the differential is only an inch or two the the side (meaning I don't think it'll fit at all even with the differential centered.
Did I screw up by cheaping out and getting just the bar? It seems the stock trac bar would be a better fit. I MIGHT be able to get it to fit if I took off the wheels, and lowered the rear end all the way, but even then I'm not sure if it'll work.
Any thoughts would be appreciated!
zplightning is offline   Reply With Quote
Old 10-10-2015, 10:52 PM   #2
Clyde65
Clyde65's Avatar
Re: Airbag Installation - Trac bar?
Single or double adjustable track bar?
I have the double and bags and all seems fine on mine
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-10-2015, 11:00 PM   #3
zplightning
I also have the double. I'm thinking I'll try in the morning and try and get it on somehow some way and see what happens.
Do you happen to remember if it's as short as it goes or did you end up threading it out?
Old 10-11-2015, 12:32 PM   #4
PGSigns
PGSigns's Avatar
You may find that the long track bar like Early classics or performance online will work better for you. If you have several inches of suspension travel the short bar can move the rear a good bit depending on where it is in the arc. The long bar lessen this movement a good bit. You have to set the rear end in the center at ride height and deal with the position when aired out.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
