10-11-2015, 04:24 PM | #1 |
1972 cracked inner grill: super glue?
I was getting ready to paint my 1972 egg crate inner grill (argent silver, thanks again guys) when I noticed a crack.
Would cyano-acrylic glue (super glue) be the fix for that? |
10-11-2015, 07:16 PM | #2 |
Re: 1972 cracked inner grill: super glue?
ttt
10-11-2015, 08:18 PM | #3 |
How about a sand-able, paint-able epoxy?
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
10-11-2015, 08:26 PM | #4 |
I used super glue on a Chevelle I once had. Looked fine. If you want it to look perfect, what slikside said.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-11-2015, 08:29 PM | #5 |
Yes, super glue it!
10-11-2015, 10:20 PM | #6 |
I will look into an epoxy as suggested and use super glue as a back up. After the crack is repaired, it will be primed and painted over. Thanks.
10-11-2015, 10:29 PM | #7 |
SWB 4x4 Collector
MEK with a scrap piece of the plastic your are working on. Put the scrap in a little bit of the MEK in a jar and close up. Wait a day and your have a liquid weld of plastic that you can now apply to the joint like super glue. The best part is it is plastic and fuses a lot of plastics back together. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
10-11-2015, 10:35 PM | #8 | |
I assume I'd have to open up the crack a bit (like grinding open a steel crack to make room for a penetrating weld)? |
10-12-2015, 07:38 AM | #9 |
Super glue will do it and be done without any further work. I have this stuff I haven't used yet that claims to molecularly bond materials. The demo was very convincing. I asked if it would bond anything other than molecules, he thought about it a second, and answered NO" One of his first lines is Super Glue is old technology. I say it demonstrated at two different shows this year and it's good stuff. Claims it will bond a broken fan belt together. He cut a rubber cord, used this, and had you pull one end and it will not let go, just stretch and stretch. He cut through the bond lengthwise and you couldn't tell where it looked like one piece never cut
www.tech-bond.net
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-12-2015 at 08:13 PM. |
10-12-2015, 08:06 AM | #10 | |
SWB 4x4 Collector
10-12-2015, 12:58 PM | #11 |
I've used ABS plastic cement to repair automotive plastic trim pieces. It works great, and you can use some scrap ABS to make a slurry of glue and 'molten' plastic to fill in gaps. I've used a heat gun (carefully) to speed up the hardening process.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
10-12-2015, 06:34 PM | #12 |
SWB 4x4 Collector
Most abs cements are based with MEK.
10-25-2015, 12:34 PM | #13 |
Well I just Crazy Glued it. If that doesn't work, I'll try the ABS or MEK mentioned above.
