Old 10-16-2015, 02:33 PM   #1
createthis
createthis's Avatar
Question Rear sliding window seal?
Howdy folks,
I've been blocked on my rear sliding window replacement project for a few weeks now. I was wondering if you folks could help me get unstuck.
I accidentally broke the sliding window by using my softtopper as a makeshift hammer. No big deal, I thought, throw some money at it and it'll be fixed in a week. Ha. Not that simple, apparently.
I bought a replacement sliding window and seal from lmctruck.com, then I took it to my local glass shop. They were really hesitant to even talk to me about it. I guess they see this stuff a lot? I dunno. I dropped the truck off and they gave me a call a few hours later saying the seal was too big. I said, "email me a picture and I'll get a replacement from lmctruck." Here's the photo the glass shop sent me:
So, I called lmctruck, sent them the photo via email, and they sent me a replacement. When the replacement arrived, I took a picture and emailed it to the glass shop:
The glass shop said it's still too big. I called lmctruck again, and they told me: "Per our research department the seal should be larger than the glass. Once installed, the rubber will compress into the bodywork and around the glass and will seal correctly. The seal and glass install simultaneously, which can be extremely difficult."
So, my part vendor won't give me another part and my installer won't install what I have.
I asked the installer if they could cut it to size. They said they couldn't. It would leak if they did that.
How should I proceed? Thanks!
Jesse
CreateThis
createthis is offline   Reply With Quote
Old 10-16-2015, 02:40 PM   #2
truckster
truckster's Avatar
Re: Rear sliding window seal?
It's definitely going to be too big. It's not going to magically shrink into place, either. The seal should be tight on the glass before it goes into the sheet metal.
The glass shop could cut it at a lower corner and use urethane to glue it together, but that might be more work than they want to do.
truckster is offline   Reply With Quote
Old 10-16-2015, 02:45 PM   #3
createthis
createthis's Avatar
Awesome. So, where can I get a seal that'll actually fit then?
Alternatively... I guess I could cut it and glue it myself and supply it to the shop...
Jesse
CreateThis
Old 10-16-2015, 03:48 PM   #4
truckster
truckster's Avatar
I would think one of the vendors on the board would have the correct seal. Does the seal have a brand name on it (other than LMC)?
Old 10-16-2015, 04:17 PM   #5
cdowns
cdowns's Avatar
have you held that slider up to the window spot in the cab to see if in fact it is the proper slider?
Old 10-16-2015, 04:58 PM   #6
createthis
createthis's Avatar
I have not personally, but the glass shop said the window was the right size, but the seal was too big.
Jesse
CreateThis
Old 10-16-2015, 06:07 PM   #7
John Pasinski
John Pasinski's Avatar
I bought my slider from a board member.
I then bought a gasket & chrome trim through GMC PAUL'S.
The body shop was unable to install as it was too tricky.
I had to pay a window glass installer and even then it took him 3 hours.
He said these windows are a bear. Not sure if he meant the deluxe trim, or just the slider itself.
Your gasket looks too large by the way.
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
Old 10-16-2015, 06:46 PM   #8
truckster
truckster's Avatar
Did he try to put the trim in after he installed the slider? The rear window (slider or flat glass, either way) is a pretty simple install. But if you don't put the trim into the rubber before you install it, you're going to have a bad day.
Old 10-16-2015, 08:37 PM   #9
Sliders take the same seal as the solid glass. Precision makes the best. Obviously LMC makes the worse...not even close. The sliders never came with trim, only the standard seal. I used a Precision seal and that bugger worked me hard...TIGHT! And that's a good thing
Old 10-17-2015, 01:41 AM   #10
createthis
createthis's Avatar
I guess that would be... this guy: http://www.jcwhitney.com/p3039135/sk...51327y1971g2j1
Worth a try. Thanks!
Jesse
CreateThis
Old 10-17-2015, 09:29 AM   #11
That's cool JC Whitney is selling the good stuff. Many 67-72 vendors deal in Precision. They have the rep for being the best
Old 10-17-2015, 12:11 PM   #12
cypressbog
Go Pack Go!
Originally Posted by createthis View Post
I guess that would be... this guy: http://www.jcwhitney.com/p3039135/sk...51327y1971g2j1!
I'm not sure this will work. The description says small window.
cypressbog is offline   Reply With Quote
Old 10-17-2015, 12:24 PM   #13
Jrainman
Jrainman's Avatar
Ok so I saw this post last night , and I have a slider NIB that I got with my truck when I bought it . when I first took it out of the box and looked at it a couple months ago , I thought is was not the right window and figured wrong part bought by PO.
Then this morning I pulled it from the box and compared it to my OEM window and gasket. well it is correct .there was no company name on the box ,but on the glass it reads Tempered customs .
Now when I came back here to post my findings ,I looked at your pictures again and came to the conclusion
A) you have a 73-87 slider
B) you have a 73-87 gasket
I think the 73- 87 widow is larger So my money is on you are trying to install a 73-87 gasket on a 68-72 window.
Jrainman is offline   Reply With Quote
Old 10-25-2015, 01:03 PM   #14
createthis
createthis's Avatar
Just got around to doing this. Far as I can tell, eyeballing it, it's a good fit. Same size. Now to find a gasket that fits...
Jesse
CreateThis
Old 10-25-2015, 01:11 PM   #15
createthis
createthis's Avatar
You can put your money on whatever you want, but I suggest you avoid putting it on part number 38-5916 from lmctruck: http://www.lmctruck.com/features/cb/cb9bq.htm
Does not fit the slider they sell for the same model year (part number 38-4800 http://www.lmctruck.com/features/cb/CBPTW.htm ), and they think that's just fine and won't do anything about it. Terrible customer service.
Jesse
CreateThis
Old 11-05-2015, 07:23 PM   #16
createthis
createthis's Avatar
Yep. That one was too small. Sigh. Shipped it back today.
Jesse
CreateThis
Old 11-05-2015, 07:37 PM   #17
Grumpy old man
Grumpy old man's Avatar
Hi , Call the guys at manes truck parts (mom and pop shop ) They have the best customer service and great prices and super fast shipping
http://www.manestruckparts.com/index.cfm
looks like the gasket you need is $34.95
http://www.manestruckparts.com/store...Category_ID=22
