Old 10-19-2015, 03:06 PM   #1
WarMonger
WarMonger's Avatar
Engine wiring question Purple and green
I pulled out my 350 motor and we built a 383 stroker. On my old started, there were 2 wires that ran down to it. I believe purple and green??? My new starter is a high torque one. It only has 1 position for a wire. So.............If i'm correct, one of those wires is the start wire that will go to the starter and the other wire is a run wire that needs keyed 12V?
let me know. Thanks
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 10-19-2015, 03:10 PM   #2
leftybass209
leftybass209's Avatar
Re: Engine wiring question Purple and green
On my setup, only 1 wire from the harness is used with hei. The yellow wire is taped back and covered up. Purple to the solenoid, and starter connection, and that's it.
leftybass209 is offline   Reply With Quote
Old 10-19-2015, 03:21 PM   #3
WarMonger
WarMonger's Avatar
Ok, when I land the motor I will try that. If I have running issues, then I guess I will need to dig out that wire and find somewhere to put it?
1970 C20
-_--_--_- ______
1972 K5
Old 11-05-2015, 05:18 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
The yellow wire provides power to the coil through the solenoid when cranking the engine to start it. If you tie it off, you may have a lot of cranking since you won't be powering the coil. You'd have to get it spinning and let the ignition catch when you let go of the key. I get around this by using a remote solenoid from a competing automotive manufacturer to provide power while cranking.
~Steven
Simi Valley, CA
Old 11-05-2015, 05:24 PM   #5
Fitz
That wire is not used on an HEI distributor. You use a "key on hot" on the HEI '+' terminal instead.
Fitz is offline   Reply With Quote
Old 11-05-2015, 06:46 PM   #6
87Skier
87Skier's Avatar
x2. I have HEI, with a newer style starter. Distributor is directly wired up (red wire), purple going to starter, and the green/yellow wire is taped up.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 11-05-2015, 06:47 PM   #7
WarMonger
WarMonger's Avatar
Thats what I did and it worked great.
1970 C20
-_--_--_- ______
1972 K5
Old 11-06-2015, 09:11 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
I didn't say it was used on the HEI, I told him what it is for, and gave him an alternative, since that wire will be tied off.
~Steven
Simi Valley, CA
