Old 10-19-2015, 09:49 PM   #1
blown240
blown240's Avatar
Death Wobble After Ball Joint Swap
I put a new upper ball joint on my panel this weekend. I also removed a couple of the camber shims to get the wheel to not lean out, and took out a 1" wheel spacer.
I drove it today for the first time since the work, and at 40-45 mph it gets a bad wobble. It had a wobble when I first bought it, but new tires got rid if it.
What can cause this?
1. Ball joint isn't tight.... I tightened it with the front off the ground and the suspension hanging.
2. Tire is worn odd, and causing this
3. Tire toe is bad is toe out
4. $$$
under 40 mph i barely feel the wobble, but at 45 it gets bad.
Thoughts? Ideas?
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 10-19-2015, 09:55 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Death Wobble After Ball Joint Swap
Did you get an alignment?
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-19-2015, 10:02 PM   #3
blown240
blown240's Avatar
Not yet. Have to save a bit to get one. Only guy around here that will do it wants $160. I can set the toe on my own. Ive done that a few times.
Old 10-19-2015, 11:03 PM   #4
blown240
blown240's Avatar
After talking to a buddy I am going to double check that the ball joint is tight with the wheel on the ground, then swap that tire to the rear to see if the wobble goes away or moves. I will report back....
Old 10-19-2015, 11:19 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
You must have the ball joint fully seated and tight in the spindle or very bad things can happen, including the stud breaking off at speed. Get that sorted out before you drive it anymore, period.
Next thing is, if any of the steering parts are worn out and you do not have a good alignment, this will cause problems like drifting, darting and wobbles. Again, get this sorted out now.
Steering and brakes are NOT any place to mess around with. Your life and others around you depend on it. Make sure they are right or do not drive it.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-19-2015, 11:24 PM   #6
blown240
blown240's Avatar
Thanks for the reply Mike.
I tightened the crap out of the joint, but that was without weight on the suspension. Ill check it again tomorrow with the wheels on the ground. Maybe the joint has seated in the spindle more...
Old 10-19-2015, 11:29 PM   #7
joedoh
joedoh's Avatar
more than likely, your truck was aligned with worn suspension parts. when you replaced one balljoint, it likely took out some slack that was being compensated for in the alignment. having even half a turn extra on a tie rod will cause bad wobbling/shaking.
check your toe in/out with a tape measure in front of and behind the front tires with the wheels pointing straight ahead. even a small difference between the two measurements will indicate poor alignment.
weight on or off the balljoint when tightening does not make a difference, it is a tapered fit and once it is tight, it is tight.
Old 10-19-2015, 11:30 PM   #8
chevy_mike
chevy_mike's Avatar
You are supposed to torque them to specific specs. I am not sure what they are for a '61. Tighten the crap out of is not a correct torque setting. You could have stretched the threads and it won't tighten correctly.
If they were loose in the spindle, you could have already messed up the taper in the spindle and you'll never get them to seat correctly.
Old 10-19-2015, 11:38 PM   #9
blown240
blown240's Avatar
I know that the alignment is off. It's a bit toe out. You can see it by looking at the tires. I guess that means it's a TON off.
I'll have to set the toe. What good? 1/16 toe in? 1/8?
Old 10-19-2015, 11:38 PM   #10
blown240
blown240's Avatar
Also, thanks for the input. I appreciate it!
Old 10-19-2015, 11:41 PM   #11
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Here Try This
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 10-20-2015, 12:21 AM   #12
blown240
blown240's Avatar
Thanks for the torque specs! I'll check it tomorrow!!
Old 10-20-2015, 02:10 AM   #13
joedoh
joedoh's Avatar
Ive always been told slightly out is better for cornering, in for more high speed stability. this will flip flop going from negative camber to positive camber. when I do a driveway alignment I set it almost exactly zero. I dont drive around at 9/10ths like most people.
If you can see it, its WAY out.
Old 10-20-2015, 06:27 AM   #14
PGSigns
PGSigns's Avatar
Easy way to tighten the upper ball joint. Jack the truck just on that side jacking it near the end of the lower control arm. Put a jack stand under the truck and pull the wheel. leave the weight on the jack. This allows you to easily seat the taper with out working against the spring.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-20-2015, 10:24 AM   #15
blown240
blown240's Avatar
Thanks Jimmy! I'll do it that way for sure.
Old 10-20-2015, 02:41 PM   #16
blown240
blown240's Avatar
I went out just now and made sure the ball joint was torqued correctly. It was, so I rotated the front tire to the back and vise versa. I haven't had a chance to drive it yet, but hopefully this helps.
Also, I found that my torque limiting impact extensions are garbage. They only torque to about half their rating. I used my clicker torque wrench and torqued all the lugs to 60 ft/lb. Maybe that was causing some of the issue too.
Still haven't had time to measure toe...
Old 10-20-2015, 07:43 PM   #17
blown240
blown240's Avatar
UPDATE:
I went for a drive and the wobble is 75% better, which is good, but not good enough.
I measures the toe and the front of the tires are 1/4 wider than the rear of the tire. This is measuring at the exact same spot on the tread front and rear, left and right.
How do I determine which tie rod to adjust? Or just adjust them both?
Thanks!
Old 10-20-2015, 07:56 PM   #18
PGSigns
PGSigns's Avatar
If the steering wheel is centered then do them both.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 10-20-2015, 08:18 PM   #19
picklito
Thoughts? Ideas?
Did you remove equal thickness of front and rear shims? If, for example, you removed more from the front, you lost the very little caster these trucks have to begin with. Also, removing these shims, all else being equal, will move the specs toward toe-out, as it sounds you have discovered.
Hope that helps!
picklito is offline   Reply With Quote
Old 10-20-2015, 11:35 PM   #20
blown240
blown240's Avatar
I removed equal thickness shims from the front and rear of the wheel. Good to know it can make it toe out, that explains a lot!
Thanks!
Old 10-21-2015, 12:01 AM   #21
paulspickupparts
Could be a lot of things. You replaced the ball joints. Have you checked tie rod ends, center link joints , pitman arm joint, wheel bearings? If you only replaced the ball joints there is a good chance your have other worn parts.
Tires and or rims can often create this problem. With a loose front end the tire or rim either being out of balance, slipped belt , bent rim , loose lug nuts, worn steering box, etc can start the oscillation. Putting on the brakes will sometimes put enough tension on the system it will stop . Other times it is necessary to bring the vehicle to a complete stop. I think you have other issues besides the ball joint.
Here is what I would like to say. But they have said it better than me. Had the same problem in a big truck. It ended up being a worn drag link ( I beam axle truck ) . Good reading if this link works.
http://www.souzastireservice.com/tir...d-wobbles.aspx
paulspickupparts is offline   Reply With Quote
Old 10-21-2015, 01:02 AM   #22
blown240
blown240's Avatar
Thanks for the reply Paul. Tie rods are good, there is a bit of play in the steering
Box, but not much. I'm going to dial in the toe and I'll report back.
Old 10-21-2015, 12:13 PM   #23
bonacker
I've always thought it best to replace ball joints in pairs (both top or both bottom). You didn't say why just one was replaced. Top ball joints wear less than bottom joints, so I'm sure you checked those already. As for the death wobble, it could be a combination of things, but tight suspension and steering parts along with an alignment should cure it. One thing to look at is how much play in the steering box and is the rag joint still good. Another possibility is a bent rim. Oh, and $160.00 for an alignment??? Wow, that is high. No other places to go to? Nearby town? It takes time, but keep at it and you'll nail it down.
bonacker is offline   Reply With Quote
Old 10-21-2015, 12:16 PM   #24
blown240
blown240's Avatar
Thanks for the reply. I only replaced the one ball joint because it was the only one that had play in it. All the joints have been replaced at some point before I got the truck.
There are other alignment shops, but none will work on a car this old. Ill get it as close as I can, and if necessary, save up and spent the $160.
Old 10-21-2015, 01:57 PM   #25
Evoracer
Eberhardt's Fullerton, $95. It's where I got mine done...
Evoracer is offline   Reply With Quote
