Old 02-21-2004, 08:25 PM   #1
rn2fine
rn2fine's Avatar
Speedo Cable - To Lube or Not to Lube
Just bought a new speedo cable for my 72 Burb. It is complete with both the inner metal cable and the outer sheath with the screw on connectors for the transmission and speedo. The inner cable appears dry. Should I lube it prior to installation? If yes, what should I use?
72 C10 Burb 350 700R4
70 C20 LWB 350 Crate TH400
68 Chevelle
rn2fine is offline   Reply With Quote
Old 02-21-2004, 08:32 PM   #2
70short/step
70short/step's Avatar
Yes lube it. I have always used a graphite spray, But I am sure a light weight lithium grease would work just fine. You do not want to use an oil or spray such as WD-40.
Good Luck, 70short/step
70short/step is offline   Reply With Quote
Old 02-21-2004, 09:17 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yup, what he said. I have used lithium grease on mine with no problem, but I understand it's not the best for very cold climates. In Arizona, you should be fine with either grease or graphite.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-21-2004, 10:37 PM   #4
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
I just bought a new cable too and instructions said to lube.......checked in side box and it came with a small tube of lube...............
72-SUPER CHEYENNE/20 LONGHORN
70-C/30 DUALLY
Castiron9 is offline   Reply With Quote
Old 02-21-2004, 11:43 PM   #5
Blue Beard
Blue Beard's Avatar
Yup, lube it.......that is unless you want to replace her again....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-21-2004, 11:46 PM   #6
sixbangr
sixbangr's Avatar
speedo shop told me to use petromium jelly(vasoline) and nothing else
1961 Apache short step.
sixbangr is offline   Reply With Quote
Old 02-22-2004, 12:44 AM   #7
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
That's........... funny the stuff that came in the little tube in my box was exactly like "vasoline"''''''''''one more "lubricant"to have around the shop........... ................
70-C/30 DUALLY
Old 02-22-2004, 12:45 AM   #8
rn2fine
rn2fine's Avatar
Thanks guys. No lube came with the cable so I bought a tube of Permatex white lithium grease and coated the cable, then installed it.
Jeff
68 Chevelle
