10-23-2015, 04:41 PM | #1 |
q-jet issues after smog removal
84 454. removed all smog related stuff. rerouted vacuum lines. starts fine, high idle cold, runs down the road way better than ever but once warm refuses to idle.... is this common? is it a simple adjust the idle screws fix? thanks, steve.
and no, there are no vacuum leaks. I have thoroughly checked and verified that..
1972 gmc 3500 ramp truck, 350, sm465, dana 70 rear |
10-24-2015, 05:13 PM | #2 |
Re: q-jet issues after smog removal
From your description, sounds like a simple cold idle speed screw adjustment. Did you move the vacuum advance to a manifold source? That can help with low and mid throttle response.
