Old 10-24-2015, 01:59 PM   #1
aotte1
Repairing Deluxe Heater Levers Help
I am repairing deluxe heater levers, two of them appear to be broken where knob fits. Can the heater and defrost levers be interchanged, e.g. if I find a good replacement heater lever can I use it in the defrost position?
Can the knobs be removed from levers without breaking or if you need knobs do you need to replace lever and knob as one piece?
thanks,
Les
aotte1 is offline   Reply With Quote
Old 10-24-2015, 04:57 PM   #2
tmck
tmck's Avatar
Re: Repairing Deluxe Heater Levers Help
I have these levers and knobs left over from my project if you're interested. I believe the two outside ones interchange and the middle one is different.
tmck is offline   Reply With Quote
Old 10-24-2015, 06:10 PM   #3
Steve66
I changed mine last year with a repair kit I got from LMC. I think it was made by Old Air or something like that. The new levers were stamped steel instead of pot metal and came with the knobs, bushings and retainers to reattach the cables. It was easy to install and works fine. Like the above poster said I believe that two of them are the same and the other one is different.
Steve66 is offline   Reply With Quote
Old 10-24-2015, 07:01 PM   #4
scuderia
scuderia's Avatar
Just did mine as well with LMC kit and the whole job took less than two hours... Also picked up a new fan motor from LMC for $30. 15 min. to swap and it's nice and quiet now. As Steve66 mentioned the LMC levers are stamped and appear to be more durable. With all the broken original levers out there seems it's just a mater of time..
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 10-24-2015, 07:14 PM   #5
jdl71
jdl71's Avatar
I have used the ones from Classic Parts also, and worked just as well. No more than these are unless you are on a super tight budget I'd just order new.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 10-24-2015, 07:19 PM   #6
aotte1
Thanks everybody for the help.
TMCK your photos raises another questions, were all the year knobs labeled with fan, def, etc?
Yes, interested in your extra parts, mine is 64 to 66 controls.
Les
Old 10-24-2015, 07:35 PM   #7
jdl71
jdl71's Avatar
64-66 were not labeled, those were 60-63.
Psalm 23
64 C10
66 K20
Old 10-25-2015, 01:56 AM   #8
tmck
tmck's Avatar
The knobs in the picture are from a 65 GMC.
Old 10-25-2015, 09:45 AM   #9
jdl71
jdl71's Avatar
Thanks for the correction, I hadn't considered GMC.
Psalm 23
64 C10
66 K20
Old 10-25-2015, 11:56 AM   #10
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Sometimes the same parts are less expensive at:
http://www.classicparts.com/Heater-P...oducts/214/3/0
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
