#276 |
Re: Color Wiring Diagram FINISHED
For all the guru's, PO put a HEI in my '70. It's wired to the 12P, but it's constant hot for some reason. Put a new ignition switch in the truck and still the same issue. Traces back all the way to the switch. Also currently the unfused ignition slots and the fuse above are constant hot.
Any suggestions? I'm tempted to just run another switched power wire, but that doesn't explain why I'm getting a constant hot. |
#277 |
can someone email me a copy? cavazosmark@hotmail.com
#278 |
The diagrams are great but they aren't for a GMC with the four eyes up front and AC. Anyone have a diagram for a '68 GMC with factory AC?
#279 |
Hey could I get an email of the larger version please chris_san2011@yahoo.com
#280 |
I spent some time (a lot of time actually) re-drawing this in Adobe Illustrator so everything would be easier to read. There are a couple minor edits based on what I have found in my two trucks.
Send me a PM with your email address if you would like me to send it to you. |
#281 |
Email me the actual files??
Spoonpappy@gmail.com |
#282 | |
#283 |
I have a 1972 GMC suburban, and the wiring is driving me crazy. The diagrams I found on here look similar to what I see under the hood but not exactly. Also, I don't see the blue wire that is supposed to be to the oil pressure on my harness but my guage cluster does have a oil pressure guage. The engine harness actually only has 5 wires. I unplugged it and looked at the female plug on the firewall and it also only has 5 inserts. The five wires I have are the tan, dark green, purple,pink, and brown with white. Can someone chime in?
#284 |
Thank you for taking the time to make a diagram like this! if possible could you e-mail me a copy at ctoydoc@gmail.com
Thank you!! |
#285 | |
#286 |
#287 | |
#288 |
on this diagram, is the alternator on the driver side, labeled " A.C.F GEN R....or something like that?
#289 |
I too would like one emailed to me at twbailey75@yahoo.com. Thanks
#290 |
![]() Join Date: Nov 2015
#291 |
![]() Join Date: Apr 2014
#292 |
#293 |
#294 |
I would like one please. fgsltwthg@aol.com
#295 |
Just scanned the pages looking for a wiring diagram for the 1959 GMC.
Does anyone have? I might even make a Chevy one work too... TIA
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
#296 |
Does anybody have a diagram for a 57 apache? I bought a new harness with updated fuse box kit. Ive got the basics hooked up. The motor runs again. I can figure it out but a reference would make it easier.
Thanks guys |
#297 |
![]() Join Date: Dec 2015
Did a high-res version ever get posted anywhere? Also, can I assume the diagram is the same regardless of the engine?
#298 |
Re: I suck at reading wiring diagrams..
#299 |
Can I get a digram to Please sent to garciajulian@grandecom.net Thanks
#300 |
Please copy sent andy.j.bock@gmail.com
Thank you |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
