Old 10-25-2015, 11:56 AM   #1
dragon65
my 65 coming alive
http://67-72chevytrucks.com/vboard/a...1&d=1445787895
I figured I would get a picture out there since its taken 3 years to get to this point
Im in the process of reconstructing a truck I've never seen together or driven for that matter except around the yard as of 4 weeks ago after I mounted the cab on the finished frame. I will construct a build sheet as soon as I get time. I will say that this forum and the guys here are the greatest most informed group especially in the 60-66 catagory that is very specific to my build
I salute you all for this great wealth of knowledge
I will do my best to input responses from what I have learned
dragon65 is offline   Reply With Quote
Old 10-25-2015, 01:43 PM   #2
RANDY COX
RANDY COX's Avatar
Re: my 65 coming alive
we need more pixs...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 10-25-2015, 02:16 PM   #3
dragon65
Im going to get a couple more up shortly
Old 10-25-2015, 02:31 PM   #4
dragon65
http://67-72chevytrucks.com/vboard/a...1&d=1445797784
Old 10-25-2015, 02:36 PM   #5
dragon65
http://67-72chevytrucks.com/vboard/a...1&d=1445798040
Old 10-25-2015, 05:54 PM   #6
dragon65
http://67-72chevytrucks.com/vboard/a...1&d=1445809920
Heres the start of roof removal
Old 10-25-2015, 05:57 PM   #7
dragon65
http://67-72chevytrucks.com/vboard/a...1&d=1445810142
Insulation before roof skin replaced
Old 10-25-2015, 06:01 PM   #8
dragon65
http://67-72chevytrucks.com/vboard/a...1&d=1445810332
Hood before the black-green shot in first pic
Old 10-25-2015, 06:08 PM   #9
dragon65
http://67-72chevytrucks.com/vboard/a...1&d=1445810710
Motor rebuilt 33,000 miles mounted back on completed frame
Old 10-25-2015, 06:14 PM   #10
dragon65
http://67-72chevytrucks.com/vboard/a...1&d=1445811218
Old 10-25-2015, 06:57 PM   #11
Mikes66ChevyC10
Mikes66ChevyC10's Avatar
Truck looks great! I see you got the right gas tank from the truck shop.
1966 C10 Stepside swb
http://67-72chevytrucks.com/vboard/s...d.php?t=617778
Mikes66ChevyC10 is offline   Reply With Quote
Old 10-26-2015, 03:57 AM   #12
dragon65
Sure did Mike. They were pretty quick on switching it out for me
Thanks!
Old 10-26-2015, 07:42 AM   #13
dragon65
http://67-72chevytrucks.com/vboard/a...1&d=1445859430
Double layered insulation for sound deadening- road noise.
U-seal is used under a product called reflectix. Its 1/3 the cost of the insulating sound mats and great results and user friendly
Sorry for the sideway pics but i can't seem to adjust them after loading.
Old 10-26-2015, 11:23 AM   #14
Mikes66ChevyC10
Looks nice! Where did you buy the reflectix from?
Old 10-26-2015, 11:49 AM   #15
dragon65
Reflectix can get at home depot or lowes. Lowes has a bigger variety on size. I got a 25' roll i think it was 2' wide. I used an adheisive spray to adhere it to the Useal. Useal is great underneath due to its rubber backing that sticks right to the metal and the top is foil ...it is non butyl so theres no rubber odor
Old 10-26-2015, 11:52 AM   #16
dragon65
Now my preformed carpet will go right over it with perfect fit and it feels great without the carpet
Old 10-26-2015, 12:03 PM   #17
TJ's Chevy
TJ's Chevy's Avatar
Nice truck! Glad to see the 6 banger was saved.
Old 10-26-2015, 01:14 PM   #18
dragon65
Thank you Tj!!
=the motor only has 33,000 i had the upper end seals replaced for acceptace of unleaded gas.
Old 10-26-2015, 02:13 PM   #19
TJ's Chevy
TJ's Chevy's Avatar
Thank you Tj!!
Nice! I kept my 292 and built it for street performance and backed it by a tko600. Always nice to see something different lurking under the hood. lol
Old 10-26-2015, 06:23 PM   #20
dragon65
Tj,
What would be a lowball cost to get my engine set up like yours......only one problem mine is a 250...is it feasible?
Nice trucks you have !!!
Old 10-26-2015, 07:24 PM   #21
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Nice looking build!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-26-2015, 09:34 PM   #22
TJ's Chevy
TJ's Chevy's Avatar
Tj,
It cost about $6000 to do mine. Your 250 is actually considered the better engine of the 2. You can use 307 flat top pistons in yours for a compression boost and since they are V8 pistons the cost is literally half as much compared to a super set of ross pistons. I can't really give you a Good estimate unless you tell me exactly what your wanting out of the engine. Street performance that will make a small block cring, or a just above stock build for a little more go. You have a TON of options. Prices to do machine work will vary per state. But parts I can give you a definite price on. You can start with the outside mods...then work on the inside later if your not satisfied. That's how I did it. Took a bone stock 292 and installed a 4 barrel, headers, and HEI...was really happy with the gains....then decided to go deeper:
Head work:
BBC 1.75 ratio full roller rockers
Z/28 valve springs
1.94 intake valves
1.60 exhaust valves
Had the bowls opened up as well.
.030 shaved off the head.
Block work:
Zero decked.
.040 Ross forged aluminum pistons with an 18 CC dish vs 30 CC stock.
Stock rods fitted with ARP studs and bolts.
Crank shaft balanced and ground
Comp cam 268H 219 @ .050 .499 lift on a 110 lobe center.
Clevite bearings
Melling oil pump.
Smith brother's pushrods.
And then the accessories. lol Expected HP is 310 and torque should be around 340 at the flywheel.
You could do the exact same head work, flat top pistons, and with .520 lift on the cam make 310 hp and 280 torque and have a 6000 RPM 6 banger. lol!
Check out these videos. This is a 250 that Hauls!
https://www.youtube.com/watch?v=3NU7n3kOWe8
https://www.youtube.com/watch?v=iXdFLCIz-BA
Old 10-26-2015, 09:40 PM   #23
jdl71
jdl71's Avatar
Is this a GMC or Chevrolet? I didn't think GMC's came with a 250-6. Also, you have any more to share about getting it "in a box"? Would love to hear the back story. Love the color scheme also, can't wait to see it finished.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 10-26-2015, 09:44 PM   #24
TJ's Chevy
TJ's Chevy's Avatar
It has a GMC grill and hood. lol So if it is a GMC with the stock engine it will have a 230. But a 250 crank and rods will drop in and make it a 250. lol Same bore just different strokes.
Old 10-26-2015, 09:48 PM   #25
jdl71
jdl71's Avatar
I saw that, but I thought it looked like it had a Chevy dash, although hard to tell. And I thought GMC's all had a V-6 until 66.
Psalm 23
64 C10
66 K20
