Old 10-28-2015, 09:07 PM   #176
55 Chevy Dave
55 Chevy Dave's Avatar
My 1955 Chevy 3100 build
I did a fair amount of work on the fenders as well. I filled the mounting holes for the badges, repaired stress cracks at some of the mounting holes and filled the antenna hole.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=654899
55 Chevy Dave is offline   Reply With Quote
Old 10-28-2015, 09:22 PM   #177
55 Chevy Dave
I put the front end back together to see how everything fit and to see if anything else needed to be fixed at the connection points of the panels. Everything seems to fit pretty well.
Old 10-28-2015, 09:27 PM   #178
55 Chevy Dave
I filled in the rear sections of the floor above the cab corners where I cut out the cab corners and ground everything smooth. Based on the posts of others here on the forum, I decided not to weld the seam solid to avoid warping the cab corner. I will fill the gaps with seam filler later.
Old 10-28-2015, 09:40 PM   #179
55 Chevy Dave
Finally onto the first of the front fender patch panels. I hung the doors to make sure I had the fenders lined up properly and then fit the patch panel in place. Everything seemed to go pretty well.
The last pic is from the other night when I was putting a coat of wax on the new truck.
Old 10-28-2015, 10:06 PM   #180
Advanced Design
Advanced Design's Avatar
Re: My 1955 Chevy 3100 build
Really nice metal repairs. Great progress.
Advanced Design is offline   Reply With Quote
Old 10-28-2015, 11:18 PM   #181
oldman3
oldman3's Avatar
Repairs looking great...Jim
oldman3 is offline   Reply With Quote
Old 10-29-2015, 07:59 AM   #182
Kim57
Kim57's Avatar
Very nice job on all the repairs.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-29-2015, 08:08 AM   #183
II_Slow
II_Slow's Avatar
I think mine is getting exactly the same repairs, plus a little work on the hinge pockets. Thanks for posting the pictures, gives me more confidence to proceed on mine. Yours is looking great, rock on with it!
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and
47RH AOD transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=640042
II_Slow is offline   Reply With Quote
Old 10-29-2015, 03:37 PM   #184
RockinKees
RockinKees's Avatar
Nice repairs Dave!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 10-29-2015, 04:38 PM   #185
ptc
ptc's Avatar
Ditto here! - I am just getting ready to do the fender lowers and the door lowers. did you have any problems with warping any of the panels due to heat? or just take it real slow! ???
Also on assembling the fenders to the front radiator support, do you have to assemble the inner fenders first before installing onto truck? cause mine dont seem to fit afterwards.... thx!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 11-03-2015, 04:20 PM   #186
made2drag
made2drag's Avatar
WOW! Amazing build so far. Your metal work is stellar man!
made2drag is offline   Reply With Quote
Old 11-15-2015, 10:07 PM   #187
55 Chevy Dave
Thank you for all the compliments. I appreciate all of you taking the time to look at my thread. It makes the time spent working on the thread worthwhile.
Old 11-15-2015, 10:11 PM   #188
55 Chevy Dave
PTC, I did have problems with the first fender warping. When I did the second fender, I had a rag soaking in bucket of water nearby. After a few welds, I would put down the welder and soak everything down with the rag. It took a lot longer but made the difference!
I assemble the inner and outer fenders on the truck. If I leave everything loose, there is enough play to move all of the panels around and make sure everything fits together properly.
Old 11-15-2015, 10:29 PM   #189
55 Chevy Dave
The passenger side took a bit longer than the driver's side, but the fender ended up nice and straight.
Old 11-15-2015, 10:38 PM   #190
55 Chevy Dave
I took the fender off of the truck and welded up the back side, stopping frequently to cool everything down with my wet rag. I then smoothed everything out.
I cut off the bottom of the old brace on the back side of the fender. It wasn't very rusty, but a previous owner had attempted a repair and did not do a very good job. I welded in a new brace and went back to grinding.
Old 11-15-2015, 10:42 PM   #191
55 Chevy Dave
Here's the final product. Too bad the driver's side didn't come out this nice! I'll be going back to fix it up soon enough!
Old 11-15-2015, 10:49 PM   #192
55 Chevy Dave
I moved onto the dash. I started by cutting out the two holes for the switches to the left of the gauge cluster. I cut out two filler pieces out of 18 gauge sheet metal, welded them in place and grinded everything smooth.
Old 11-15-2015, 10:58 PM   #193
55 Chevy Dave
The dash will be completely smoothed out without any knobs or the glove compartment. I cut out most of the sheet metal to the right side of the gauge cluster. The dash is indented on the right side to allow the glove box door to close flush with the dash. I cut out the indented part and removed a section of it. I then cleaned it up in preparation for reinstallation.
Old 11-15-2015, 11:05 PM   #194
55 Chevy Dave
After removing a section of the removed piece, I was able to slide it forward and line it up with the rest of the dash. I clamped it in place, welded it in and smoothed everything out.
Old 11-15-2015, 11:14 PM   #195
55 Chevy Dave
After a lot of trimming, test fitting, trimming again and test fitting again, I was finally able to clamp in the smooth dash panel and weld it into place.
Old 11-15-2015, 11:21 PM   #196
55 Chevy Dave
And here's the final product after grinding it up, welding up a few spots and grinding again. It looks so much better than the mess that was in there before!
I'm feeling good about all the work I got done this weekend! To bad I have to go back to work tomorrow!
Old 11-16-2015, 12:12 AM   #197
oldman3
oldman3's Avatar
Nice job, you should be proud...Jim
Old 11-16-2015, 12:30 AM   #198
Kim57
Kim57's Avatar
Looking very nice.
Kim
My build thread
Old 11-16-2015, 11:14 AM   #199
Advanced Design
Really good work Dave. Came out nice.
Old 11-16-2015, 01:53 PM   #200
slck57
Very nice!
slck57 is offline   Reply With Quote
