#351 |
Re: 67-72 Electric speedo
Shine up all of the exposed brass, especially the nail head terminal on the temp sender Any corrosion/green color/dark brass is additional resistance and will skew your dash gauge colder. Good luck
#352 |
Interested in a set.
#353 |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#354 |
Hey Ls1nova, I'm interested and ready to purchase a faceplate set from you. Can you please PM me the details.
#355 |
does anyone covert these as a side business? I have the template from LS1NOVA and can get the parts from captianfab but not sure if i have the skills to make this happen myself.
#356 |
60-66 Nut
You might send a PM to member Tbone1964. He is in the business of rebuilding gauge clusters. Also member PGSigns has started rebuilding '64-'66 clusters, but I don't know if he does any other years.
#357 |
i started by askeing TBONE1964. He said he doesn't convert them anymore. But thanks for the other name I will look into it.
#358 |
![]() Join Date: Jan 2009
Are you still doing the vinyl faces. Interested in getting a set
65 Chevy C10 Short Fleet BBW 6.0L/4l80E 68 Chevy C10 SWB 6.0L/4L80E 84 Chevy C10 SWB 5.3/4l60E QA1 Suspension |
#359 |
Yes, I still have them. PM sent
#360 |
sorry if i'm just not seeing this, but i can't find the socket ya'll are using for the dash lights, i just seeing lots of different ideas. Can someone who has done the conversion post a link to one that they know works? Thanks for your help in advance
#361 |
Post number 321 gives the part number and how to slightly modify them to work. It's on page 13 of this posting
#362 |
thank you for describing where it is
#363 |
I cut it out with a cut off wheel and sanded the edges smooth with a DA sander. You're right, tin snips would probably be hard to use and would likely crack it.[/QUOTE]
I took the trip reset off then cut it out with a band saw, and then sanded the burs off with a piece of 120 grit sand paper. Could do the same think with a jig saw for those of you that don't have a band saw |
#364 |
Are there still sets available? If so I would like to get one
#365 |
Yes, PM sent.
#366 |
The paint for my numbers was so thick that the polishing compound wouldn't work, i wet sanded it with 2000 grit sand paper, then used some medium cut compound to get rid of the scratches.
#367 |
I'd like to know this too...would be cool to also swap that tach
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#368 |
![]() Join Date: Feb 2014
#369 |
^^^^^ Nice job, looking real good!
#370 |
I'm a little confused on how we are supposed to set up the fake face plate screws, does anyone have pictures of how they set it up?
#371 |
Basically, you just drill a small hole in the face and they just push in, and if the hole isn't too big, they will stay in there. You will have to mark and drill holes under the face with a bigger drill bit so that the screw part has somewhere to go. I found this to be easier than trying to cut the head off the little screw and gluing them on like I did the first time.
#372 | |
#373 |
PM Sent on getting a set of these.
Current: 2012 Ford F-250 4x4 6.7 Powerstroke 1971 C-20 2wd 350/TH400 Former: 1979 C-20 2wd 350/TH400, 300+hp. Rattle can paint job 1982 K-30 454/700R4. 4in lift with 37" Goodyear MT/R's Lots of goodies - Trail clean up truck |
#374 |
Hey Eric,
Any way I can get another speedo decal sent my way. Changing some things around. Thanks |
#375 |
Ok. I'm currently doing this right now. I've got a question, when the needle is straight up and down its at 50mph. The sticker I'm putting on straight up and down will be 60 mph. Is the speedometer correction in the tune?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
