Old 11-01-2015, 10:06 PM   #1
Jeff's bowtie's
How rare is a 6 lug Dana 60
I just purchased a 69 GMC swb 2wd roller with a Dana 60 leaf sprung rear with 6 lugs this is the first one I've seen just wondering if this is a rare option thanks Jeff
Jeff's bowtie's is offline   Reply With Quote
Old 11-01-2015, 10:22 PM   #2
Kennuck
Kennuck's Avatar
Re: How rare is a 6 lug Dana 60
I know they put these in the Jeep Pickups. It was a semi floating Dana 60 in those. Is yours a semi or full float?
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 11-01-2015, 10:28 PM   #3
Jeff's bowtie's
Semi floating I've seen a few Dana 44 back rears in the 2wd GMC but not 60 s
Old 11-01-2015, 10:31 PM   #4
1972RedNeck
1972RedNeck's Avatar
I know Ford used a few of them in the '60's.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 11-02-2015, 12:45 PM   #5
Mike C
Mike C's Avatar
Ford never used a 6 lug setup. Jeep used it but only on the Wagoneers if the recall working.
The 6 lug semi-float Dana 60 is pretty uncommon. If memory serves it was only in 1/2 ton 2x4 with the close ratio 4 speed? And I thought it was only '67-'68, but you never know!
It was not at all common and would be awesome to swap into a 4x4 that you wanted to beef up the rear without going to 8 lug.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-02-2015, 02:17 PM   #6
Jeff's bowtie's
This is why I bought the frame to do a 4x4 conversion the Dana 60 is a big plus the frame has the manual bell housing cross member in it hoping it is 3:73 ratio as I have a 72 Dana 44 front with disc & 3:73
Old 11-02-2015, 06:03 PM   #7
Kennuck
Kennuck's Avatar
Jeep used them in the J Trucks too. I had one.
1970 Short Wide
Vintage Air
Old 11-02-2015, 07:58 PM   #8
Jeff's bowtie's
I pulled the cover off today everything looks good its an open carrier with 46-13 stamped on ring gear I'm guessing 3:55 gear ratio
Old 11-03-2015, 04:21 AM   #9
68shortfleet
What's to guess. That's basic math.
3.54 gears.
68shortfleet is offline   Reply With Quote
Old 11-03-2015, 08:25 AM   #10
Jeff's bowtie's
This is true !!
Old 11-03-2015, 09:02 AM   #11
Mike C
Mike C's Avatar
3.54 not a common Dana 44 gearset unfortunately, so looks like a re-gear in your future in one of the axles.
I wound up with a semi-float 14 bolt in my Jimmy which is near Dana 60 strength. Only drawback is the c-clip axles instead of bolt in axles like the 60 has, but still a tremendous increase in strength over the 12 bolt.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 11-03-2015, 04:38 PM   #12
Jeff's bowtie's
Yeah I'll most likely go 3:73s in the Dana 60 definitely a up grade from the 12 bolt
